Detectned_V2 bbox
Description
I trained Detectned_V2 in Transfer Learning Toolkit on kitti dataset (It was very comfortable).
Now i want to use this model in TensorRT(Not in deepstream) in my own c++ aplication.
TensorRT engine has 2 outputs: output_cov/Sigmoid and output_bbox/BiasAdd.
I want to get probability and bounding boxes.
As I understand for probability i must use some variant of DBSCAN algorithm for output_cov/Sigmoid and NMS for output_bbox/BiasAdd
Is there some C++ code sources for postprocessing this outputs (especially for output_cov/Sigmoid postprocessing)?
Another information that i cant find - Is it necessary for this model to use some preprocessing (using mean value)?
Environment
nvcr.io/nvidia/tlt-streamanalytics:v2.0_dp_py2
Please refer to below sample if in case it helps:
I successfully received output_cov/Sigmoid
But i cant receive right bboxes
top- my boxes(all predicted box fromo utput_bbox/BiasAdd ); bot - TLT result
CODE:
outputIndex1 = engine.getBindingIndex(“output_bbox/BiasAdd”);
float box3[4 * 24 * 78];
cudaMemcpyAsync(box1, buffers[outputIndex1], 4 * 24 * 78 * sizeof(float), cudaMemcpyDeviceToHost, stream);
cudaStreamSynchronize(stream);
///Postprocessing
for (int i = 0; i < 24 * 78; ++i)
int dx = (i % 78) ;
int dy = (i / 78) ;
float x1 = (box1[i * 4 + 0] + dx) * 16;
float y1 = (box1[i * 4 + 1] + dy) * 16;
float x2 = (box1[i * 4 + 2] + dx) * 16;
float y2 = (box1[i * 4 + 3] + dy) * 16;
cv::rectangle(image, cv::Point(x1, y1), cv::Point(x2, y2), cv::Scalar(0, 255, 0), 1, 8, 0);
Something wrong in my output_bbox/BiasAdd postprocessing.
Regards.
Please refer to below sample:
Hi mazitov
Have you found the proper way to postprocess the output? I would be very apperciated if you can share your code.
Regards
#include <src/cnn/nvdsinfer.h>
#include <src/cnn/nvdsinfer_dbscan.h>
void Cnn::assignClass(std::vector &objectList, std::vector &objectListRes,
int num)
int objNum = objectList.size();
if (objNum < 1)
return;
for (int i = 0; i < num; ++i)
objectListRes[i].classId = objectList[0].classId;
float ax = objectListRes[i].left + objectListRes[i].width / 2;
float ay = objectListRes[i].top + objectListRes[i].height / 2;
float bx = objectList[0].left + objectList[0].width / 2;
float by = objectList[0].top + objectList[0].height / 2;
float dist = sqrt((ax - bx) * (ax - bx) + (ay - by) * (ay - by));
for (int j = 1; j < objNum; ++j)
bx = objectList[j].left + objectList[j].width / 2;
by = objectList[j].top + objectList[j].height / 2;
float distItr = sqrt((ax - bx) * (ax - bx) + (ay - by) * (ay - by));
if (dist > distItr)
dist = distItr;
objectListRes[i].classId = objectList[j].classId;
void Cnn::doInference(IExecutionContext& context, float* inputData, cudaStream_t &stream)
cudaMemcpyAsync(buffers[inputIndex0], inputData, batch_size * INPUT_D * sizeof(float), cudaMemcpyHostToDevice, stream);
context.enqueue(batch_size, buffers, stream, nullptr);
float probs[classNum * OUT_DIM_H * OUT_DIM_W];
float boxs[classNum * 4 * OUT_DIM_H * OUT_DIM_W];
cudaMemcpyAsync(probs, buffers[outputIndex0], classNum * OUT_DIM_H * OUT_DIM_W * sizeof(float), cudaMemcpyDeviceToHost, stream);
cudaMemcpyAsync(boxs, buffers[outputIndex1], classNum * 4 * OUT_DIM_H * OUT_DIM_W * sizeof(float), cudaMemcpyDeviceToHost, stream);
std::vector objectList;
int gridW = OUT_DIM_W;
int gridH = OUT_DIM_H;
int gridSize = gridW * gridH;
float gcCentersX[gridW];
float gcCentersY[gridH];
float bboxNormX = 35.0;
float bboxNormY = 35.0;
float *outputCovBuf = (float *) probs;
float *outputBboxBuf = (float *) boxs;
int strideX = DIVIDE_AND_ROUND_UP(INPUT_W, gridW);
int strideY = DIVIDE_AND_ROUND_UP(INPUT_H, gridH);
for (int i = 0; i < gridW; i++)
gcCentersX[i] = (float) (i * strideX + 0.5);
gcCentersX[i] /= (float) bboxNormX;
for (int i = 0; i < gridH; i++)
gcCentersY[i] = (float) (i * strideY + 0.5);
gcCentersY[i] /= (float) bboxNormY;
for (int c = 0; c < classNum; c++)
float *outputX1 = outputBboxBuf + (c * 4 * gridW * gridH);
float *outputY1 = outputX1 + gridSize;
float *outputX2 = outputY1 + gridSize;
float *outputY2 = outputX2 + gridSize;
float threshold = 0.02;
for (int h = 0; h < gridH; h++)
for (int w = 0; w < gridW; w++)
int i = w + h * gridW;
if (outputCovBuf[c * gridSize + i] >= threshold)
NvDsInferObjectDetectionInfo object;
object.classId = c;
object.detectionConfidence = outputCovBuf[c * gridSize + i];
float rectX1f, rectY1f, rectX2f, rectY2f;
rectX1f = (outputX1[w + h * gridW] - gcCentersX[w]) * -bboxNormX;
rectY1f = (outputY1[w + h * gridW] - gcCentersY[h]) * -bboxNormY;
rectX2f = (outputX2[w + h * gridW] + gcCentersX[w]) * bboxNormX;
rectY2f = (outputY2[w + h * gridW] + gcCentersY[h]) * bboxNormY;
/* Clip object box co-ordinates to network resolution */
object.left = CLIP(rectX1f, 0, INPUT_W - 1);
object.top = CLIP(rectY1f, 0, INPUT_H - 1);
object.width = CLIP(rectX2f, 0, INPUT_W - 1) - object.left + 1;
object.height = CLIP(rectY2f, 0, INPUT_H - 1) - object.top + 1;
objectList.push_back(object);
size_t numObjects = objectList.size();
auto unclasteredObjectList = objectList;
NvDsInferDBScanCluster(DBScan, &DBScanParams, &objectList[0], &numObjects);
assignClass(unclasteredObjectList, objectList, numObjects);
for (int i = 0; i < numObjects; ++i)
auto object = objectList[i];
cv::Scalar color(255, 255, 0);
if (object.classId == 0)
color = cv::Scalar(0, 255, 0);
else if (object.classId == 1)
color = cv::Scalar(255, 0, 0);
else if (object.classId == 2)
color = cv::Scalar(0, 0, 255);
cv::rectangle(visualize, cv::Rect(object.left, object.top, object.width, object.height), color, 2, 8, 0);
Hi mazitov
Thanks for sharing your code.
Where is the source code of this method
I did found the header file in DeepStream SDK, but I can’t found the source code
