How to run Detectnet_v2_resnet18.trt without deepstream
Hi all,
1- I trained the detectnet_v2_resnet18 on kitti dataset using TLT, and output of model is (N,12,24,78), and (N,3,24,78), How to convert these outputs to boxs and scores?
I saw in this repo mention, this output of this model, but for bbox it’s different with that link, that’s wrong?
2- I want to know, what’s prepossessed algorithms used in this network?
Could you please paste again for “this repo”? The link is broken.
please refer to Detectnet_v2:
link
  1. For postprocess, please refer to the ode which is exposed in C++ in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer_customparser/nvdsinfer_custombboxparser.cpp .
  2. For preprocess, please refer to Run PeopleNet with tensorrt - #6 by Morganh
I convert the postprocess of nvdsinfer_custombboxparser.cpp to python codes and the bboxes incorrect.
Is nvdsinfer_custombboxparser.cpp for detectnet_v2_resnet18?
Yes, it is for detectnet_v2.
So in that file :
float bboxNormX = 35.0;
float bboxNormY = 35.0;
detectnet_v2 has varites of resnet backbone 10/18/50, and input dim maybe change so in this situation I guess that above value can’t valid for any input size, right?
When resnet backbone changes, the input dim will not be changed.
Hi. Did you resolve pre- and post- processing issues? Could you please share full example of inference detectnet using c++ and tensor rt? Thanks in advance.
Hey everyone. After looking into a lot of places, blogs and repos I could manage to run a .engine or .trt file for Detectnet_v2 with preprocessing and proper postprocessing.
Here is my working code, hope it helps future persons:
import os
import time
import cv2
import matplotlib.pyplot as plt
import numpy as np
import pycuda.autoinit
import pycuda.driver as cuda
import tensorrt as trt
from PIL import Image
class HostDeviceMem(object):
    def __init__(self, host_mem, device_mem):
        self.host = host_mem
        self.device = device_mem
    def __str__(self):
        return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
    def __repr__(self):
        return self.__str__()
def load_engine(trt_runtime, engine_path):
    with open(engine_path, "rb") as f:
        engine_data = f.read()
    engine = trt_runtime.deserialize_cuda_engine(engine_data)
    return engine
def allocate_buffers(engine, batch_size=1):
    """Allocates host and device buffer for TRT engine inference.
    This function is similair to the one in common.py, but
    converts network outputs (which are np.float32) appropriately
    before writing them to Python buffer. This is needed, since
    TensorRT plugins doesn't support output type description, and
    in our particular case, we use NMS plugin as network output.
    Args:
        engine (trt.ICudaEngine): TensorRT engine
    Returns:
        inputs [HostDeviceMem]: engine input memory
        outputs [HostDeviceMem]: engine output memory
        bindings [int]: buffer to device bindings
        stream (cuda.Stream): cuda stream for engine inference synchronization
    inputs = []
    outputs = []
    bindings = []
    stream = cuda.Stream()
    # Current NMS implementation in TRT only supports DataType.FLOAT but
    # it may change in the future, which could brake this sample here
    # when using lower precision [e.g. NMS output would not be np.float32
    # anymore, even though this is assumed in binding_to_type]
    binding_to_type = {
        "input_1": np.float32,
        "output_bbox/BiasAdd": np.float32,
        "output_cov/Sigmoid": np.float32,
    for binding in engine:
        size = trt.volume(engine.get_binding_shape(binding)) * batch_size
        dtype = binding_to_type[str(binding)]
        # Allocate host and device buffers
        host_mem = cuda.pagelocked_empty(size, dtype)
        device_mem = cuda.mem_alloc(host_mem.nbytes)
        # Append the device buffer to device bindings.
        bindings.append(int(device_mem))
        # Append to the appropriate list.
        if engine.binding_is_input(binding):
            inputs.append(HostDeviceMem(host_mem, device_mem))
        else:
            outputs.append(HostDeviceMem(host_mem, device_mem))
    return inputs, outputs, bindings, stream
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
    # Transfer input data to the GPU.
    [cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
    # Run inference.
    context.execute_async(
        batch_size=batch_size, bindings=bindings, stream_handle=stream.handle
    # Transfer predictions back from the GPU.
    [cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
    # Synchronize the stream
    stream.synchronize()
    # Return only the host outputs.
    return [out.host for out in outputs]
def process_image(arr, w, h):
    image = Image.fromarray(np.uint8(arr))
    image_resized = image.resize(size=(w, h), resample=Image.BILINEAR)
    img_np = np.array(image_resized)
    # HWC -> CHW
    img_np = img_np.transpose((2, 0, 1))
    # Normalize to [0.0, 1.0] interval (expected by model)
    img_np = (1.0 / 255.0) * img_np
    print(img_np.shape)
    img_np = img_np.ravel()
    return img_np
def predict(image, model_w, model_h):
    """Infers model on batch of same sized images resized to fit the model.
    Args:
        image_paths (str): paths to images, that will be packed into batch
            and fed into model
    img = process_image(image, model_w, model_h)
    print(img.shape)
    # Copy it into appropriate place into memory
    # (self.inputs was returned earlier by allocate_buffers())
    np.copyto(inputs[0].host, img.ravel())
    # When infering on single image, we measure inference
    # time to output it to the user
    inference_start_time = time.time()
    # Fetch output from the model
    [detection_out, keepCount_out] = do_inference(
        context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream
    # Output inference time
    print(
        "TensorRT inference time: {} ms".format(
            int(round((time.time() - inference_start_time) * 1000))
    # And return results
    return detection_out, keepCount_out
# -------------- MODEL PARAMETERS FOR DETECTNET_V2 --------------------------------
model_h = 544
model_w = 960
stride = 16
box_norm = 35.0
grid_h = int(model_h / stride)
grid_w = int(model_w / stride)
grid_size = grid_h * grid_w
grid_centers_w = []
grid_centers_h = []
for i in range(grid_h):
    value = (i * stride + 0.5) / box_norm
    grid_centers_h.append(value)
for i in range(grid_w):
    grid_centers_w.append(value)
def applyBoxNorm(o1, o2, o3, o4, x, y):
    Applies the GridNet box normalization
    Args:
        o1 (float): first argument of the result
        o2 (float): second argument of the result
        o3 (float): third argument of the result
        o4 (float): fourth argument of the result
        x: row index on the grid
        y: column index on the grid
    Returns:
        float: rescaled first argument
        float: rescaled second argument
        float: rescaled third argument
        float: rescaled fourth argument
    o1 = (o1 - grid_centers_w[x]) * -box_norm
    o2 = (o2 - grid_centers_h[y]) * -box_norm
    o3 = (o3 + grid_centers_w[x]) * box_norm
    o4 = (o4 + grid_centers_h[y]) * box_norm
    return o1, o2, o3, o4
def postprocess(outputs, min_confidence, analysis_classes, wh_format=True):
    Postprocesses the inference output
    Args:
        outputs (list of float): inference output
        min_confidence (float): min confidence to accept detection
        analysis_classes (list of int): indices of the classes to consider
    Returns: list of list tuple: each element is a two list tuple (x, y) representing the corners of a bb
    bbs = []
    class_ids = []
    scores = []
    for c in analysis_classes:
        x1_idx = c * 4 * grid_size
        y1_idx = x1_idx + grid_size
        x2_idx = y1_idx + grid_size
        y2_idx = x2_idx + grid_size
        boxes = outputs[0]
        for h in range(grid_h):
            for w in range(grid_w):
                i = w + h * grid_w
                score = outputs[1][c * grid_size + i]
                if score >= min_confidence:
                    o1 = boxes[x1_idx + w + h * grid_w]
                    o2 = boxes[y1_idx + w + h * grid_w]
                    o3 = boxes[x2_idx + w + h * grid_w]
                    o4 = boxes[y2_idx + w + h * grid_w]
                    o1, o2, o3, o4 = applyBoxNorm(o1, o2, o3, o4, w, h)
                    xmin = int(o1)
                    ymin = int(o2)
                    xmax = int(o3)
                    ymax = int(o4)
                    if wh_format:
                        bbs.append([xmin, ymin, xmax - xmin, ymax - ymin])
                    else:
                        bbs.append([xmin, ymin, xmax, ymax])
                    class_ids.append(c)
                    scores.append(float(score))
    return bbs, class_ids, scores
# TensorRT logger singleton
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_engine_path = os.path.join("YOUR .TRT FILE HERE")
trt_runtime = trt.Runtime(TRT_LOGGER)
trt_engine = load_engine(trt_runtime, trt_engine_path)
# This allocates memory for network inputs/outputs on both CPU and GPU
inputs, outputs, bindings, stream = allocate_buffers(trt_engine)
# Execution context is needed for inference
context = trt_engine.create_execution_context()
image = cv2.imread("YOUR IMAGE HERE")[..., ::-1]
detection_out, keepCount_out = predict(image, model_w, model_h)
NUM_CLASSES = 2
threshold = 0.1
bboxes, class_ids, scores = postprocess(
    [detection_out, keepCount_out], threshold, list(range(NUM_CLASSES))
image_cpy = image.copy()
image_cpy = cv2.resize(image_cpy, (model_w, model_h))
# Final bboxes only take afet NMS
indexes = cv2.dnn.NMSBoxes(bboxes, scores, threshold, 0.5)
for idx in indexes:
    idx = int(idx)
    xmin, ymin, w, h = bboxes[idx]
    class_id = class_ids[idx]
    color = [255, 0, 0] if class_id else [0, 0, 255]
    cv2.rectangle(image_cpy, (xmin, ymin), (xmin + w, ymin + h), color, 2)
plt.imshow(image_cpy)
plt.show()
Thanks, @carlos.alvarez for sharing your code .is there any similar way to do inference on trt file with c++.
