Incorrect Results When Using TensorRT Inference Server With TLT Model
I am using TLT pre-trained model DashCamNet cache file (the weights and config file from DeepStream SDK) for inference using TensorRT. The issue here is the bounding boxes are off from the regions of interest.
Here’s the code snippet that I am using for preprocessing and parsing the output:
float net_scale_factor = 0.0039215697906911373;
cv::cvtColor(frame,frame,CV_BGR2RGB);
int kINPUT_C = 3, mHeight = 544, mWidth = 960;
uint8_t buffer[kINPUT_C * mHeight * mWidth];
int nCols = mWidth* kINPUT_C, nRows = mHeight;
if (frame.isContinuous())
    nCols *= nRows;
    nRows = 1;
uchar* p;
for(int i = 0; i < nRows; ++i)
    p = frame.ptr<uchar>(i);
    for (int j = 0; j < nCols; ++j)
        buffer[i*nCols+j] = p[j];
for (int i = 0, volImg = kINPUT_C * frame.rows * frame.cols; i < mMaxBatchSize; ++i)
    for (int c = 0; c < kINPUT_C; ++c)
        // The color image to input should be in RGB order
        for (unsigned j = 0, volChl = mWidth * mHeight; j < volChl; ++j)
            data[i * volImg + c * volChl + j] = float(buffer[j * kINPUT_C + 2 - c])*net_scale_factor;
cudaMemcpy(mInputCUDA, data, mInputSize, cudaMemcpyHostToDevice);
// process with GIE
void* inferenceBuffers[] = { mInputCUDA, mOutputs[0].CUDA, mOutputs[1].CUDA };
if( !mContext->execute(1, inferenceBuffers) )
    printf(LOG_GIE "Failed to execute tensorRT context\n");
    numBoundingBoxes = 0;
Here are the results when I’m using the above code for inference: https://gofile.io/d/MSMbqU
Sample screenshot of the inference results(from the video above):
Can anyone please tell me if I am missing something here?
• Hardware Platform : Jetson AGX Xavier
• DeepStream Version : 5.0
• JetPack Version : 4.4 Developer Preview
• TensorRT Version : 7.1.0
Please try to run inference with DS firstly.
Reference: https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#intg_detectnetv2_model
The inference results were accurate with DS.
So, please refer to postprocess code which is exposed in C++ in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer_customparser/nvdsinfer_custombboxparser.cpp .
I have referred to the code for parsing the output and I don’t think the issue is with parsing the output. It’s more to do with the input image pre-processing. Can you check if the order of the channels and netscale factor in the code are in-place?
For preprocess, please refer to Run PeopleNet with tensorrt
I have changed the line after referring to the link as follows:
data[i * volImg + c * volChl + j] = float(buffer[j * kINPUT_C + 2 - c])/255.0;
Here’s the log to give you more insight:
[GIE]  CUDA engine context initialized with 3 bindings
[GIE]  input  binding index:  0
[GIE]  input  dims (b=1 c=3 h=544 w=960) size=6266880
[cuda]  cudaAllocMapped 6266880 bytes, CPU 0x213cb9000 GPU 0x213cb9000
[GIE]   output 0 bboxes  binding index:  1
[GIE]   output 0 bboxes  dims (b=1 c=16 h=34 w=60) size=130560
[cuda]  cudaAllocMapped 130560 bytes, CPU 0x20e2a2400 GPU 0x20e2a2400
[GIE]   output 1 coverage  binding index:  2
[GIE]   output 1 coverage  dims (b=1 c=4 h=34 w=60) size=32640
[cuda]  cudaAllocMapped 32640 bytes, CPU 0x20e2c2200 GPU 0x20e2c2200
[cuda]  cudaAllocMapped 522240 bytes, CPU 0x20e2ca200 GPU 0x20e2ca200
[cuda]  cudaAllocMapped 522240 bytes, CPU 0x20e349a00 GPU 0x20e349a00
initialized.
[cuda]  cudaAllocMapped 64 bytes, CPU 0x20e3c9200 GPU 0x20e3c9200
However, the results didn’t change.
Please consider there is a step of preprocess
transpose(2, 0, 1)
I have added
cv::transpose(frame,frame);
after
when I added this, there are no bounding boxes at all.
Please double check your code.
For postprocess, refer to /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer_customparser/nvdsinfer_custombboxparser.cpp .
For preprocess, refer to Run PeopleNet with tensorrt
Hey Morganh,
I have double checked output parsing(postprocess) and input preprocessing and made sure that I am doing exactly what’s mentioned in the reference links you pointed out.
Here’s the postprocess code snippet:
    float *outputCoverageBuffer = mOutputs[OUTPUT_CVG].CPU;
    float *outputBboxBuffer =  mOutputs[OUTPUT_BBOX].CPU;
    const int ow  = mOutputs[OUTPUT_CVG].dims.d[2];		// number of columns in bbox grid in X dimension
    const int oh  = mOutputs[OUTPUT_CVG].dims.d[1];		// number of rows in bbox grid in Y dimension
    const int owh = ow * oh;					// total number of bbox in grid
    const int cls = GetNumClasses();				// number of object classes in coverage map
    unsigned int targetShape[2] = { ow, oh };
    float bboxNorm[2] = { 35.0, 35.0 };
    float gcCenters0[targetShape[0]];
    float gcCenters1[targetShape[1]];
    int strideX = DIVIDE_AND_ROUND_UP(imgW, mOutputs[OUTPUT_BBOX].dims.d[2]);
    int strideY = DIVIDE_AND_ROUND_UP(imgH, mOutputs[OUTPUT_BBOX].dims.d[1]);
    for (unsigned int i = 0; i < targetShape[0]; i++)
        gcCenters0[i] = (float)(i * strideX + 0.5);
        gcCenters0[i] /= (float)bboxNorm[0];
    for (unsigned int i = 0; i < targetShape[1]; i++)
        gcCenters1[i] = (float)(i * strideY + 0.5);
        gcCenters1[i] /= (float)bboxNorm[1];
    float preClusterThreshold = 0.10; // passed as config-file parameter in deepstream SDK
 std::vector< std::vector<float6> > rects;
 std::vector<float6> objectList;
 std::vector<std::vector<cv::Rect>> PreMergeBoundingBoxes(cls);
 std::vector<std::vector<float>> ConfidenceScores(cls);
 std::vector<std::vector<int>> ResultIndices(cls);
    for (unsigned int classIndex = 0; classIndex < cls; classIndex++)
        /* Pointers to memory regions containing the (x1,y1) and (x2,y2) coordinates
         * of rectangles in the output bounding box layer. */
        float *outputX1 = outputBboxBuffer + classIndex * sizeof (float) *oh * ow;
        float *outputY1 = outputX1 + owh;
        float *outputX2 = outputY1 + owh;
        float *outputY2 = outputX2 + owh;
        /* Iterate through each point in the grid and check if the rectangle at that
         * point meets the minimum threshold criteria. */
        for (unsigned int h = 0; h < oh; h++)
            for (unsigned int w = 0; w < ow; w++)
                int i = w + h * ow;
                float confidence = outputCoverageBuffer[classIndex * owh + i];
                if (confidence < preClusterThreshold)
                    continue;
                float rectX1f, rectY1f, rectX2f, rectY2f;
                /* Centering and normalization of the rectangle. */
                rectX1f = outputX1[w + h * ow] - gcCenters0[w];
                rectY1f = outputY1[w + h * ow] - gcCenters1[h];
                rectX2f = outputX2[w + h * ow] + gcCenters0[w];
                rectY2f = outputY2[w + h * ow] + gcCenters1[h];
                rectX1f *= -bboxNorm[0];
                rectY1f *= -bboxNorm[1];
                rectX2f *= bboxNorm[0];
                rectY2f *= bboxNorm[1];
                /* Clip parsed rectangles to frame bounds. */
                rectX1f = CLIP(rectX1f, 0, imgW - 1);
                rectX2f = CLIP(rectY1f, 0, imgW - 1);
                rectY1f = CLIP(rectX2f, 0, imgH - 1);
                rectY2f = CLIP(rectY2f, 0, imgH - 1);
                //Prevent underflows
                if(((rectX2f - rectX1f) < 0) || ((rectY2f - rectY1f) < 0))
                    continue;
                objectList.push_back(make_float6(classIndex, rectX1f,
                         rectY1f, (rectX2f - rectX1f),
                         (rectY2f - rectY1f), confidence));
                PreMergeBoundingBoxes[classIndex].push_back(cv::Rect(cv::Point2f(rectX1f, rectY1f),cv::Point2f(rectX2f,rectY2f)));
                ConfidenceScores[classIndex].push_back(confidence);
Can you please let me know if I’m missing anything?
I am afriad your preprocessing did not aim to RGB and CHW.
Hello Morganh,
Here’s the modifed snippet code I am using for the required input format(RGB and CHW):
  cv::Mat pixels;
  frame.convertTo(pixels, CV_32FC3, 1.0 / 255, 0);  // frame is the Input Mat from video source
	int channels = 3;
	std::vector<float> img;
	std::vector<float> data (channels * imgW * imgH);
	if (pixels.isContinuous())
		img.assign((float*)pixels.datastart, (float*)pixels.dataend);
	else {
		std::cout << "Error reading image " << std::endl;
	for (int c = 0; c < channels; c++) {
		for (int j = 0, hw = imgW * imgH; j < hw; j++) {
			data[c * hw + j] =  img[channels * j + 2 - c] ;
   size_t dataSize = data.size() * sizeof(float);
   cudaMemcpy(mInputCUDA, data.data(), dataSize, cudaMemcpyHostToDevice);
The issue still persists. Can you please tell me how do I proceed?
Some comments about RGB and CHW here. Hope it helps you implement the code.
For opencv, after imread, the Mat data will be:
b0, g0, r0, b1, g1, r1, b2, g2,r2, …
For detectnet, it needs:
r0, r1, r2, … g0, g1,g2, … b0, b1, b2, …
That’s RGB+ CHW.
Hey Morganh,
I have understood the input requirement and the code snippet I posted in my previous reply does exactly the job of RGB+CHW (r0, r1, r2, … g0, g1,g2, … b0, b1, b2, …)
Copying the pixels in order of RGB+CHW into data and data is copied to device memory
I don’t see any difference in the results.
So, suggest you to run inference against one jpg/png file to narrow down your issue.
For example, Just like How to run purpose built model Peoplenet on Jetson Nano in my own application?
