DetectNet Error With ONNX model
Mr.Dusty
The DetectNet work error with ONNX model, I retrained the ssd-mobilev2-net to detect fruit (i.e. eight fruit object classes trained for one epoch with 6500 images in the dataset), when the .py running ,it showed as fllow:
device GPU, /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx initialized.
detectNet – using ONNX model
detectNet – maximum bounding boxes: 1
detectNet – loaded 9 class info entries
detectNet – number of object classes: 1
But i have 8 classes, it only show one and the web-camera detect noting but BACKGROUND.
This is my labels:
BACKGROUND
Apple
Banana
Grape
Orange
Pear
Pineapple
Strawberry
Watermelon
Here is the log:
jetson.inference. init .py
jetson.inference – initializing Python 3.6 bindings…
jetson.inference – registering module types…
jetson.inference – done registering module types
jetson.inference – done Python 3.6 binding initialization
jetson.utils. init .py
jetson.utils – initializing Python 3.6 bindings…
jetson.utils – registering module functions…
jetson.utils – done registering module functions
jetson.utils – registering module types…
jetson.utils – done registering module types
jetson.utils – done Python 3.6 binding initialization
jetson.inference – PyTensorNet_New()
jetson.inference – PyDetectNet_Init()
jetson.inference – detectNet loading network using argv command line params
jetson.inference – detectNet. init () argv[0] = ‘–model=/home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx’
jetson.inference – detectNet. init () argv[1] = ‘–class_labels=/home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/labels.txt’
jetson.inference – detectNet. init () argv[2] = ‘–threshold=0.1’
jetson.inference – detectNet. init () argv[3] = ‘–input_blob=input_0’
jetson.inference – detectNet. init () argv[4] = ‘–output_cvg=scores’
jetson.inference – detectNet. init () argv[5] = ‘–output_bbox=boxes’
detectNet – loading detection network model from:
– prototxt NULL
– model /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx
– input_blob ‘input_0’
– output_cvg ‘scores’
– output_bbox ‘boxes’
– mean_pixel 0.000000
– mean_binary NULL
– class_labels /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/labels.txt
– threshold 0.100000
– batch_size 1
[TRT] TensorRT version 7.1.3
[TRT] loading NVIDIA plugins…
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - ONNX (extension ‘.onnx’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx.1.1.7103.GPU.FP16.engine
[TRT] loading network profile from engine cache… /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx.1.1.7103.GPU.FP16.engine
[TRT] device GPU, /home/a508/workspace/jetson-inference/python/training/detection/ssd/models/fruit/ssd-mobilenet.onnx loaded
[TRT] Deserialize required 5069869 microseconds.
[TRT] device GPU, CUDA engine context initialized with 3 bindings
[TRT] binding – index 0
– name ‘input_0’
– type FP32
– in/out INPUT
– # dims 4
– dim #0 1 (SPATIAL)
– dim #1 3 (SPATIAL)
– dim #2 300 (SPATIAL)
– dim #3 300 (SPATIAL)
[TRT] binding – index 1
– name ‘scores’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #1 3000 (SPATIAL)
– dim #2 9 (SPATIAL)
[TRT] binding – index 2
– name ‘boxes’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #2 4 (SPATIAL)
[TRT] binding to input 0 input_0 binding index: 0
[TRT] binding to input 0 input_0 dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 scores binding index: 1
[TRT] binding to output 0 scores dims (b=1 c=3000 h=9 w=1) size=108000
[TRT] binding to output 1 boxes binding index: 2
[TRT] binding to output 1 boxes dims (b=1 c=3000 h=4 w=1) size=48000
Hi @2652857759, how many epochs did you train the model for?
If you run the model on some static test images like the link below, does it work?
You can also try my fruits model that I trained for 100 epochs to see if that makes a difference:
