DetectNet_v2 documentation Typo
Description
Hi, I don’t know if this is the right place, but I think it is the closest what I found ^^
I have found a typo in the Documentation for the DetectNet_v2 Network in TAO Toolkit.
The section “Sample Usage of the Dataset Converter Tool” presents the ‘dataset_convert’ function. In the first example, the name is miswritten to “dataset-convert”, therefore the execution of the command will fail. The following example it is correct.
On the same page, in the “Dataloader” section, there is the same mistake in a text passage.
Environment
Relevant Files
Steps To Reproduce
Hi @nkaaf ,
This issue belongs to TAO platform.
Moving it.
@nkaaf
Thanks for the catching! Yes, it should be dataset_convert instead of dataset-convert.
We will improve the document. Thanks.
