• Hardware Platform (Jetson / GPU) AGX Xavier
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.2/4.4
I had four cameras installed. And it works fine if I using following gstreamer pipeline:
gst-launch-1.0 nvarguscamerasrc sensor-id=$1 !
“video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080” ! nvvideoconvert ! nvegltransform ! nveglglessink
where $1 could be 0,1,2,3
And I also
ls /dev/video*
and got:
/dev/video0 /dev/video1 /dev/video2 /dev/video3
But when I try to use the following opencv and python to open /dev/video0, the system got stuck at ret, frame = cap.read() and no video show up:
import cv2
cap=cv2.VideoCapture(0)
if not (cap.isOpened()):
print "Could not open video device"
#To set the resolution
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 1280)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 720)
while(True):
# Capture frame-by-frame
# Display the resulting frame
cv2.imshow('preview',frame)
#Waits for a user input to quit the application
if cv2.waitKey(1) & 0xFF == ord('q'):
break
I did check the /dev/vidoe0 format by:
v4l2-ctl -d /dev/video0 --list-formats-ext
and it reports:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'GB10'
Name : 10-bit Bayer GBGB/RGRG
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1952x2364
Interval: Discrete 0.008s (120.000 fps)
Size: Discrete 1312x1478
Index : 1
Pixel Format: 'GB12'
Name : 12-bit Bayer GBGB/RGRG
So what should I do to get opencv/python code running to show /dev/video0 video in AGX Xavier? Thanks a lot for your help.
