hi,
I am running Jetson 4.5 on my NVIDA Xavier XDK and I noticed that the kernel automatic reboot after running some commands. After some investigation and testing and comparing with JetPack 4.3, the reboot happens because the /dev/watchdog did not see any data for ~6 seconds.
Looking at the “demsg”, I can see the WatchDog settings and timeout is set to 6 seconds.
Here is a sample “dmesg” output:
people@peope-x-x-x-x-jetpack-45:~$ dmesg | grep -i watch
[ 0.793390] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.820355] tegra-pmc: ### PMC reset source: TEGRA_BCCPLEX_WATCHDOG
[ 1.038935] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.039212] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.039250] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 13.112093] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 6 sec
How can I increase the timeout without recompile the kernel? Is there a file that I can update to send a parameter on bootup time?
Thanks ahead of time!
