I did the following test:
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod …
The result I got is a little bit confusing to me.
Thus, it is faster to copy a large amount of data than only a few thousands of bytes?
Can anybode explain this result to me?
Thank you very much!
David
Nobody has a suggestion? Please… :)
Jamie_K
#3
I don’t get the same results
And in any case I would expect the resuts to be “strange” for very small transfers.
tmurray
#4
What’s your motherboard? It’s almost certainly a BIOS issue.
Dell T5400 with Intel® 5400 chipset and Nvidia Quadro FX 3700
I did the SDK Bandwidth test:
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=*** --end=*** --increment=***
A few minutes ago, I did the test again. Same results like first post, just more values in range.
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=8 --end=1024 --increment=8
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=1024 --end=32768 --increment=1024
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=32768 --end=524288 --increment=32768
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=524288 --end=16777216 --increment=524288
bandwidthTest.exe --csv --memory=pinned --mode=range --dtod --start=16777216 --end=134217728 --increment=16777216
Here the bandwidth:
Here the time, calculated as follows:
Time [s] = Transferred_Data [Byte] / (Bandwidth [MB/s] * 1024 * 1024)
What do you mean with BIOS issue. In Detail?
