deviceQuery and nvcc check
Hi guys:
I just set up all things of CUDA on ubuntu 14.04 LTS. Before I execute ‘make’ command for compiling the CUDA Samples, I can get the information of nvcc compiler by ‘nvcc -V’. However, after I ‘make’ the CUDA Samples and reboot the system, I typed nvcc -V again, it asked me to install the nvcc compiler.
I met the trouble many times. I tried to install the nvcc compiler again after ‘make’ samples. But then I would stuck by deviceQuery failed. I guess that could be a problem of PATH or LIBRARY_PATH?
Can anyone give some ideas?
Thank you very much!
Yes, it sounds like a path problem.
Follow the directions here:
[url]http://docs.nvidia.com/cuda/cuda-getting-started-guide-for-linux/index.html#abstract[/url]
especially:
[url]CUDA Toolkit Documentation
Note to make the changes to PATH permanent, you will need to put them in a script somewhere, like .bashrc
Thank you very much, as you said, I forgot to make it permanent. Now it’s done!
