DGX Spark GB10 — fan not spinning? 80°C at idle with 0% GPU utilization
I’m seeing strong evidence of a fan hardware failure on my DGX Spark and am looking for confirmation from others who’ve seen this or from NVIDIA engineers before pursuing an RMA.
The smoking gun — anomalous idle temperature:
On 2026-05-11, I have 5-second telemetry showing the machine reached 80–86°C acpitz at 0% GPU utilization and 13W power draw — approximately 30°C above the normal idle baseline of 52°C at the same power level. This occurred before any GPU workload started.
Time (UTC) acpitz GPU°C GPU W GPU % Notes
02:32–06:07 ~52°C ~40°C 4-5W 0% Normal idle
06:08–06:32 80-86°C 52-58°C 13W 0% Anomaly — no load
06:59–08:33 93–94°C 80–84°C 83–91W 96% GPU workload started
Peak 94.3°C 84°C 93W 96% 10.5°C below ACPI critical
The machine hard-froze later that day at 19:21 UTC during a GPU run.
What I’ve already checked:
  • Fan nodes in OS: none — /sys/class/hwmon/ has no fan*_input or PWM nodes. nvidia-smi --query-gpu=fan.speed returns [N/A]. I understand fan control is firmware-only on GB10.
  • Headless boot bug: not applicable — GDM is running, monitor attached.
  • acpid: active and enabled.
  • USB-C power budget: all external USB devices disconnected. Current idle is normal (42°C at 6.5W).
  • UEFI firmware: 5.36_0ACUM018 (2025-08-06).
My question: Is the 80°C-at-idle pattern (30°C above baseline with zero GPU load) consistent with a fan hardware failure on the GB10? Has anyone else seen this? Is there any firmware-level diagnostic I’m missing before I conclude it’s a dead fan motor?
I’m attaching my telemetry CSV (dgx-flightrec.csv) — 5-second interval logging of mem, acpitz, GPU temp, GPU power, GPU util across the full day. - attached to Support Case below…
System serial: 1983925016936
Support case: #260511-000332
please install and run https://nvidia.custhelp.com/app/answers/detail/a_id/5767/~/nvidia-dgx-spark-field-diagnostics
then share the resulting logs. this will help us determine next steps.
The Spark overheats and crashes when I try to run field diagnostics. I explained all of this in my support ticket and attached the telemetry css (mentioned above).
Since the Spark crashes when running field diagnostics, please open a case with Customer Support and request RMA
Done - and waiting on my RMA number now. THanks! H
