I have vanilla Ubuntu 22.04.5 desktop. Post initial configuration of DGX Spark, I connect DGX Spark to router via ethernet cable, not wireless. My desktop is also connected to same router. With both active, I have network conflicts on my desktop. Many browser pages will not load correctly, and pages which were loaded fail to refresh. For example - Amazon Music, gmail, ongoing searches of google for example.
I have disabled ipv6 as well as avahi-daemon service and socket on DGX Spark. These troubleshooting efforts failed. I have tried boot order, desktop first, DGX Spark second and vice versa. That did not resolve my issue. I have updated with most recent updates. This has not resolved my issue. Lastly, I went to online support. And I was directed here.
What I would hope/expect, I can configure the DGX Spark to simply ask for a local address from my router via DHCP. Then I can access via ssh, port forwarding to access dashboard, etc. without having DGX Spark hijack outbound network traffic from my browser on desktop.
I’m hoping Nvidia support and/or community suggestions will lead to configuration settings which enable this result.
prm
Questions:
- Is your desktop on Ethernet or Wi-Fi to the router, and does the problem happen on other devices too or only the desktop?
- What is your router model, and do you have any “DHCP server” / “guest network” / “AP mode” / “mesh” features enabled?
- When the issue happens, what are your desktop’s default gateway IP and DNS servers, and do they match your router or the Spark?
- On the Spark, does “ss -ulpn” show listeners on UDP 67 or 53 (DHCP/DNS)? Is the Spark’s NetworkManager connection ipv4.method set to “shared”?
- Do you have a DHCP reservation for the Spark on the router, and have you seen any IP conflict warnings in the router logs?
If you don’t know the answer to those questions, I would recommend factory reset/recovery (official NVIDIA instructions):
https://docs.nvidia.com/dgx/dgx-spark/system-recovery.html
(Recovery image download page, if you need it: https://www.nvidia.com/en-us/drivers/dgx-spark-recovery-software/ )
Hi @raphael.amorim,
Thanks for the reply and suggestions on settings. Before logging out yesterday, I did an update. And this afternoon when I am online after work, I’m actually not having conflicts. That beats having to do a complete factory reset.
I did go and check the details you suggested. And once I booted the DGX, I confirmed my default gateway did not change. Likewise, my DNS server didn’t change. Then I accessed the DGX and confirmed the settings for both default gateway/DNS server matched.
So for now, I think I’m good. I’m going to close this. And thanks again for the suggestions.
prm
You’re welcome, let us know if you need help in the future
