Jetson Orin NX
• DeepStream Version
6.2
5.3.1
• TensorRT Version
8.5.2
questions
Hello, I have written an rtspserver that performs digest authentication using python as shown below. The stream receives RTP transmitted internally and serves video.
#!/usr/bin/env python
import gi
import sys
import os
gi.require_version('Gst', '1.0')
gi.require_version('GstRtspServer', '1.0')
from gi.repository import Gst, GstRtspServer, GObject, GLib, Gio
# Initialize GStreamer
Gst.init(None)
# Enable debugging
#Gst.debug_set_active(True)
#Gst.debug_set_default_threshold(Gst.DebugLevel.DEBUG)
class RTSPServer:
def __init__(self):
self.server = GstRtspServer.RTSPServer.new()
self.server.set_service('554')
username = 'admin'
password = 'pass'
self.auth = GstRtspServer.RTSPAuth()
self.auth.set_supported_methods(2)
self.token = GstRtspServer.RTSPToken()
self.token.set_string('media.factory.role', username)
self.auth.add_digest(username, password, self.token)
# Set RTSP server authentication
self.server.set_auth(self.auth)
self.permissions = GstRtspServer.RTSPPermissions()
self.permissions.add_role(username)
self.permissions.add_permission_for_role(username, "media.factory.access", True)
self.permissions.add_permission_for_role(username, "media.factory.construct", True)
self.factory1 = GstRtspServer.RTSPMediaFactory.new()
self.factory1.set_permissions(self.permissions)
self.factory1.set_launch('( udpsrc port=6001 caps="application/x-rtp" ! rtph264depay ! h264parse ! rtph264pay name=pay0 pt=96 )')
self.factory1.set_shared(True) # Allow multiple clients to connect
self.factory2 = GstRtspServer.RTSPMediaFactory.new()
self.factory2.set_permissions(self.permissions)
self.factory2.set_launch('( udpsrc port=6004 caps="application/x-rtp" ! rtph264depay ! h264parse ! rtph264pay name=pay0 pt=96 )')
self.factory2.set_shared(True) # Allow multiple clients to connect
self.mounts = self.server.get_mount_points()
self.mounts.add_factory('/Stream1', self.factory1)
self.mounts.add_factory('/Stream2', self.factory2)
self.server.attach(None)
print("RTSP server is attached and running")
if __name__ == '__main__':
loop = GLib.MainLoop()
server = RTSPServer()
print('RTSP server is running at rtsp://<IP_ADDRESS>/Stream1 and rtsp://<IP_ADDRESS>/Stream2')
try:
loop.run()
except KeyboardInterrupt:
loop.quit()
When connecting to rtsp using vlc, authentication is possible with ID and password, but if you check the wireshark message below, only digest basic authentication is performed, and “MD5” or “SHA-256” do not work.
Real Time Streaming Protocol
Response: RTSP/1.0 401 Unauthorized\r\n
CSeq: 6\r\n
WWW-Authenticate: Digest realm="GStreamer RTSP Server", nonce="eaa6c34e2102bd9e"\r\n
Server: GStreamer RTSP server\r\n
Date: Tue, 04 Jun 2024 04:38:56 GMT\r\n
\r\n
If you connect to rtsp using vlc from another general IP camera, you can see that “MD5” or “SHA-256” is supported in the wireshark message below.
CSeq: 3\r\n
Date: Tue, Jun 04 2024 13:28:09 GMT\r\n
WWW-Authenticate: Digest realm="LIVE555 Streaming Media", domain="video1", qop="auth", nonce="44f19cd397349d35dcd0b0cf2ff46dfa", opaque="", algorithm="SHA-256", stale="FALSE"\r\n
WWW-Authenticate: Digest realm="LIVE555 Streaming Media", domain="video1", qop="auth", nonce="44f19cd397349d35dcd0b0cf2ff46dfa", opaque="", algorithm="MD5", stale="FALSE"\r\n
WWW-Authenticate: Digest realm="LIVE555 Streaming Media", nonce="44f19cd397349d35dcd0b0cf2ff46dfa"\r\n
\r\n
The question I have for you is:
I would like to support “MD5” and “SHA-256” authentication in the rtspserver I wrote. How can I do this?
I am curious as to why the basic authentication of the rtspserver I wrote has a nonce length of 16 bytes, but the nonce length of other general IP cameras is 32 bytes.
