gst-rtsp-server does not build successfully on TX1
Hi!
I`ve flashed my TX1 with latest JetPack 3.1.
Then i`ve cloned&installed from GStreamer GitHub mirrors · GitHub step-by-step this repos:
each package was built with this sequence:
removing from autogen.sh --enable-gtk-doc
then
./autogen.sh
make
sudo make install
when building gst-rtsp-server i`ve got this error.
make[2]: Entering directory '/home/ubuntu/gst-rtsp-server/examples'
  CC       test-video.o
  CCLD     test-video
../gst/rtsp-server/.libs/libgstrtspserver-1.0.so: undefined reference to `gst_rtsp_message_parse_auth_credentials'
../gst/rtsp-server/.libs/libgstrtspserver-1.0.so: undefined reference to `gst_rtsp_generate_digest_auth_response'
../gst/rtsp-server/.libs/libgstrtspserver-1.0.so: undefined reference to `gst_rtsp_auth_credentials_free'
Does anybody know what to do in this situation?
It seems to me, that problem lies somewhere in gstreamer repo.
My Task is to stream some video from TX1 via RTSP.
Please refer to
[url]https://devtalk.nvidia.com/default/topic/1014789/jetson-tx1/-the-cpu-usage-cannot-down-use-cuda-decode-/post/5188538/#5188538[/url]
[url]https://devtalk.nvidia.com/default/topic/1018689/jetson-tx2/vlc-playing-gstreamer-flow/post/5187270/#5187270[/url]
This worked properly!
Target
sudo apt-get install libgstrtspserver-1.0 libgstreamer1.0-dev
test-launch.c @ https://github.com/GStreamer/gst-rtsp-server/blob/master/examples/test-launch.c
gcc test-launch.c -o test-launch $(pkg-config --cflags --libs gstreamer-1.0 gstreamer-rtsp-server-1.0)
./test-launch "videotestsrc ! omxh265enc ! rtph265pay name=pay0 pt=96"
Host
Open network stream rtsp://<TARGET_IP_ADDRESS>:8554/test via VLC
