I want to access an SSD directly from BlueField (bypassing host CPU and memory), ideally through PCIe. In this case, I am treating BlueField as an ordinary OS, and expecting a similar way of accessing SSDs.
In my current setup, I have both a BlueField DPU and an SSD attached to a host on a PCIe bus, but I cannot see the SSD from the DPU.
Are there any instructions on how to connect the devices and configure the driver? Thank you!
Thank you! If I have understood your response correctly, there are two types of BlueField cards, and only one of them (DPU Controller Cards) can suit my requirements.
I didn’t know about the difference between these two type of cards. I have an additional question. Is there any possibility to modify a BlueField-2 InfiniBand/Ethernet DPU into a DPU controller card (e.g. by reinstalling with the correct firmware)? I would like to judge whether it is necessary for our team to acquire some new cards.
