I want to disable console on UART0 or change console port. I was able to do this for Linux, but uBoot is still using UART0 for its console. I was not able to change environment variables for “stdin, stdout, stderr” (Error “22”), since they are read-only.
I have not found any working solution on complete disabling console on UART0.
Is there any compiled uBoot.bin or some instructions on how to make UART0 free of console in/out?
U-Boot is its own separate program, plus the Linux kernel takes over after it loads. So both must be disabled. When in Linux, what do you see from “cat /proc/cmdline”?
Some of what U-Boot does depends upon device tree, and it isn’t unusual for edits to not actually be put in place. The device tree used to be via a file in “/boot” (and U-Boot also now passes on some inherited command line from the device tree), but is now a partition (some boot stages from earlier than U-Boot now need that information and those stages cannot read ext4). If you changed a file in “/boot” for device tree, then this is why U-Boot did not change. What do you see from:
cat /proc/device-tree/chosen/bootargs
If updates were successful, then you will not see “console=ttyS0,115200n8”.
So far as actual command line arguments go this would be enough. Other steps in the device tree are to change its use to/from the non-DMA driver and the DMA-capable driver.
Although the U-Boot stage is incapable of using the DMA version of the driver (and by default it uses the standard non-DMA version) this would not actually change an attempt by U-Boot or Linux to use the device. In the case of U-Boot the normal setup is to use the regular driver (which exists within U-Boot), and then when Linux takes over to continue to use the same non-DMA driver. It would be useful to know which stage(s) is using the UART.
Can you provide a boot log from the serial console connector to show what is still being printed?
