In the current version of sources (28.2), I don’t have CONFIG_TEGRA_ENABLE_UARTA definition in “include/configs/p2771-0000.h” .
The header file is as follows:
- Copyright (c) 2013-2016, NVIDIA CORPORATION.
- SPDX-License-Identifier: GPL-2.0
#ifndef _P2771_0000_H
#define _P2771_0000_H
#include <linux/sizes.h>
#include “tegra186-common.h”
/* High-level configuration options */
#define CONFIG_TEGRA_BOARD_STRING “NVIDIA P2771-0000”
/* I2C */
#define CONFIG_SYS_I2C_TEGRA
/* SD/MMC */
#define CONFIG_MMC
#define CONFIG_GENERIC_MMC
#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd “boot sector” */
#define CONFIG_ENV_IS_IN_MMC
#define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_SYS_MMC_ENV_PART 2
#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* PCI host support */
#define CONFIG_PCI
#define CONFIG_PCI_PNP
#define CONFIG_CMD_PCI
/* Silence UART at start-up – my modifications --*/
#define CONFIG_DISABLE_CONSOLE
#define CONFIG_SILENT_CONSOLE
#define CONFIG_SYS_DEVICE_NULLDEV
#define CONFIG_SILENT_U_BOOT_ONLY
#define CONFIG_BOARD_EARLY_INIT_F 1
#define CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC
#define BOARD_EXTRA_ENV_SETTINGS
"calculated_vars=kernel_addr_r fdt_addr_r scriptaddr pxefile_addr_r "
“ramdisk_addr_r\0”
“kernel_addr_r_align=00200000\0”
“kernel_addr_r_offset=00080000\0”
“kernel_addr_r_size=02000000\0”
“kernel_addr_r_aliases=loadaddr\0”
“fdt_addr_r_align=00200000\0”
“fdt_addr_r_offset=00000000\0”
“fdt_addr_r_size=00200000\0”
“scriptaddr_align=00200000\0”
“scriptaddr_offset=00000000\0”
“scriptaddr_size=00200000\0”
“pxefile_addr_r_align=00200000\0”
“pxefile_addr_r_offset=00000000\0”
“pxefile_addr_r_size=00200000\0”
“ramdisk_addr_r_align=00200000\0”
“ramdisk_addr_r_offset=00000000\0”
“ramdisk_addr_r_size=02000000\0”
#include “tegra-common-post.h”
/* Crystal is 38.4MHz. clk_m runs at half that rate */
#define COUNTER_FREQUENCY 19200000
#undef CONFIG_NR_DRAM_BANKS
#define CONFIG_NR_DRAM_BANKS (1024 + 2)
#endif
Edit: I’m sorry, I noticed that I already removed that define.
