We have observed that after flashing a Jetson Xavier NX module with JetPack 5.1.4, the display behaves as follows:
When connected to a monitor with a resolution of 1920×1080 or 3840×2160 at boot time, the system displays correctly all the way through to the desktop environment.
However, when connected to a monitor with a resolution of 1440×900 or 1024×768 at boot time, the display shows the NVIDIA UEFI logo but then loses signal immediately afterward, showing no further output.
If the system first boots with a 3840×2160 display and reaches the desktop, and then the monitor is switched to 1440×900, the display works correctly.
Module: Jetson Xavier NX JetPack Version: 5.1.4 Hardware: Issue reproduced on both custom carrier boards and the official NVIDIA Developer Kit.
Could you please provide specific troubleshooting steps?
Yes, so far this issue has only been observed on JetPack 5.1.4. I’ve tested versions 4.5, 4.6, 5.1.1, and 5.1.2, and everything works normally on those.
I previously tried this operation, but the result was that regardless of whether I later connected a display with 3840×2160 or 1440×900 resolution, there was no signal output.
Sorry, my previous reply was a bit disorganized. After further testing, the behavior is as follows:
If the HDMI monitor is connected before powering on the device, both the NVIDIA developer kit and our custom carrier board exhibit no display output.
Boot logs are attached at the top as: devkit_1440x900.txt and custom_1440x900.txt.
If no monitor is connected during boot, and the HDMI display is hot-plugged only after the system is fully booted, both the NVIDIA developer kit and the custom carrier board output only: edid invalid,
but then display works normally afterward.
Just do me a favor to do a crosscheck. Please flash the “devkit” back to Jetpack4 and then try again if you could reproduce same issue with these monitors to boot up with monitor connected.
I’ve tested the approach you mentioned, and on both the NVIDIA developer kit and our custom carrier board, flashing other versions (e.g., JetPack 4.5, JetPack 4.6, JetPack 5.1.1) results in normal display output—this issue does not occur.
