I own a laptop ASUS G14 with AMD Ryzen 9 5900hs and nVIDIA RTX 3060 Mobile / Max-Q
I run Ubuntu 22.04 LTS.
I have a setup with 3 Monitors. One is an embedded monitor with the laptop, and two are standalone 27-inch and 21-inch monitors on HDMI.
On Linux, when I connect one of the monitors to the laptop’s HDMI port it will work fine and two displays will show up (the laptop’s integrated and the external).
However, if I use my display port interface (USB-C display port connected to the laptop’s display port usb C), none of the monitors will work with the Nvidia drivers on Linux.
On Windows, everything works well out of the box with the Display Port attachment.
I tried both Wayland and XORG
I tried everything on stackoverflow and around here on the forums with no success. I tried all driver packages from 470 up to 530 / meta package drivers / server / open / proprietary, manually installed, GUI, nothing seems to make this work.
Ask me what other logs to paste here. For now, check these?
lshw
sudo lshw -C display
*-display
description: VGA compatible controller
product: GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list fb
configuration: depth=32 latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:fc0-fbf iomemory:fe0-fdf memory:fb000000-fbffffff memory:fc00000000-fdffffffff memory:fe00000000-fe01ffffff ioport:e000(size=128) memory:fc000000-fc07ffff
*-display
product: Cezanne
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:04:00.0
version: c4
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list fb
configuration: depth=32 driver=amdgpu latency=0 resolution=1920,1080
resources: iomemory:fe0-fdf iomemory:fe0-fdf irq:44 memory:fe10000000-fe1fffffff memory:fe20000000-fe201fffff ioport:d000(size=256) memory:fc500000-fc57ffff
modinfo
find /usr/lib/modules -name nvidia.ko -exec modinfo {} \;
filename: /usr/lib/modules/5.19.0-41-generic/updates/dkms/nvidia.ko
firmware: nvidia/470.182.03/gsp.bin
alias: char-major-195-*
version: 470.182.03
supported: external
license: NVIDIA
srcversion: F2CDE7AABDDB6D13598C5B2
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends: drm
retpoline: Y
vermagic: 5.19.0-41-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: G14 Secure Boot Module Signature key
sig_key: 12:1B:1D:53:67:8F:97:1F:3E:D2:28:22:63:87:62:6E:AF:70:CD:6B
sig_hashalgo: sha512
signature: 63:EE:25:AF:AE:61:8A:D8:C3:EC:48:39:77:41:56:17:BA:91:77:E2:
EA:A7:92:AA:00:0A:EB:80:D4:6C:3B:41:DF:3D:92:76:F1:28:D0:D7:
AA:A1:5F:65:1A:7F:F0:58:C6:9F:93:FB:76:50:7A:BD:F1:73:DF:B7:
5F:9D:3A:67:6B:C9:7D:F7:0E:CB:1C:23:7E:4D:74:59:E7:08:2D:20:
71:17:D1:AF:41:BC:F9:A0:52:7C:D8:12:42:F6:1A:9C:3A:71:C0:E3:
7B:C7:D8:30:29:C5:92:1F:66:58:C6:4F:0D:81:17:86:98:35:74:80:
9B:AA:15:1E:0C:F2:1C:FE:1A:7D:6A:4A:93:9A:0C:ED:35:BE:82:D0:
68:7A:2A:58:2F:D4:64:A9:63:80:14:7A:00:1E:F1:D2:A5:AE:5F:13:
36:29:F0:8F:73:3C:54:D2:43:7A:4A:3F:5B:48:3C:ED:65:39:23:84:
8F:F0:C6:0D:0A:08:5B:05:67:39:FE:09:A2:84:70:8A:C0:A0:8C:03:
1D:6E:4E:63:9B:1D:21:B0:0A:6F:F9:AD:94:2D:B2:3D:AC:88:52:51:
44:3F:3B:09:57:B6:AD:07:09:CD:B6:F0:84:86:25:D2:1F:E5:E6:33:
A4:A0:D0:6D:E7:52:70:88:59:36:FA:2C:48:61:91:5D
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableGpuFirmware:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_ExcludedGpus:charp
parm: rm_firmware_active:charp
xrandr
xrandr --query
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected (normal left inverted right x axis y axis)
1920x1080 144.00 + 120.00 96.00 72.00 60.00 50.01 48.00 60.00
1680x1050 144.00
1280x1024 144.00
1440x900 144.00
1280x800 144.00
1280x720 144.00
1024x768 144.00
800x600 144.00
640x480 144.00
HDMI-A-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00 + 74.97* 72.01 60.01 50.03 48.02 50.00 59.94
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 59.90
1280x800 60.00
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
800x600 72.19 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 60.00 59.94
720x400 70.08
