Displayport Link Rate not Negotiated Correctly
Hi there,
I’m connecting my DGX Spark with direct USB-c to displayport cables. My monitors are twin 4K dispalys so in theory they should negotiate with the spark at HBR3 link rate at 120Hz (8bpp). However, both of them are stuck at 4 lanes@5.4Gbps. I suppose DSC is taking effect here which it shouldn’t.
The cables are DP2.1 certified. Same for the monitor. When I use the same cable on a macbook, they actually negotiated to 13.5Gbps per lane. I guess that means the DGX spark is the only variable. Here’s the bug report log file if anyone wants to check it.
nvidia-bug-report.log.gz (806.1 KB)
