Hello all,
I am trying to connect 2 U2713D in a daisy chain manner with the hardware and system stated in the title (Debian 7). Basically, only the first monitor is detected and I get the same image in both monitors.
There is a discussion in the Dell forums where a Dell employee states that the issue is on nVidia’s side and that we should ask here for a solution:
“Replacing the monitor will not fix the issue. We contacted Nvidia. They are aware that not all of their video cards currently support our monitors DDC/CI when DP1.2 is enabled. You need to press Nvidia and ask why your video card does not support DDC/CI when DP1.2 is enabled and when are they going to fix it.”
Is nVidia at least aware of this issue?
This doesn’t sound like a DDC/CI problem, but rather a basic functionality problem. Having it appear as one monitor and mirror the display onto the other monitor sounds like it’s running in DisplayPort 1.1 mode.
Which GPU are you connecting this monitor to, and have you enabled DP 1.2 MST support in the monitor’s configuration menu? Please attach the output of “xrandr --verbose” when both monitors are attached.
EDIT: I upgraded to 325.08 and have the same issue.
The video card is an NVS 5200M on a Dell E6530 docked in a EPort 2.
Both monitors are Dell U2713H (typo in the title). They are both configured for DP 1.2 (selected at the menu) and are daisy chained as described in the user manual (page 26):
ftp://ftp.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-u2713h_User’s%20Guide_en-us.pdf
Here is the ouput of “xrandr --verbose” with both monitors plugged:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x27b
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
BorderDimensions:
Border: CARDINAL(6) (format 16 items 4) ????
SignalFormat: VGA
supported: VGA
ConnectorType: VGA
ConnectorNumber: 1 (0x00000001)
_ConnectorLocation: 1 (0x00000001)
LVDS-0 connected (normal left inverted right x axis y axis)
Identifier: 0x27c
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
EDID:
00ffffffffffff0030e42c0300000000
00150104902213780aaf559c5b529626
0e505400000001010101010101010101
0101010101014c3680a070381f402040
360058c210000018323280b072389640
a0f0e80058c210000018000000fe0044
4339594a803135365746430a00000000
000041319e0000000002010a20200084
BorderDimensions:
SignalFormat: LVDS
supported: LVDS
ConnectorType: Panel
ConnectorNumber: 0 (0x00000000)
_ConnectorLocation: 0 (0x00000000)
1920x1080 (0x27d) 139.0MHz -HSync -VSync +preferred
h: width 1920 start 1952 end 2016 total 2080 skew 0 clock 66.8KHz
v: height 1080 start 1083 end 1089 total 1111 clock 60.2Hz
1920x1080 (0x27e) 128.5MHz -HSync -VSync
h: width 1920 start 2080 end 2320 total 2608 skew 0 clock 49.3KHz
v: height 1080 start 1094 end 1102 total 1230 clock 40.1Hz
DP-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x27f
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
ConnectorType: DisplayPort
ConnectorNumber: 2 (0x00000002)
_ConnectorLocation: 2 (0x00000002)
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x280
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 3 (0x00000003)
_ConnectorLocation: 3 (0x00000003)
HDMI-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x28e
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 4 (0x00000004)
_ConnectorLocation: 4 (0x00000004)
DP-2 connected 2560x1440+0+0 (0x290) normal (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x28f
Timestamp: 22192
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
filter:
EDID:
00ffffffffffff0010ac92a04c453830
30160104b53c22783a1df5ae4f35b325
0d5054a54b008100b300d100714fa940
8180d1c00101565e00a0a0a029503020
350055502100001a000000ff00433646
304b3242533038454c0a000000fc0044
454c4c205532373133480a20000000fd
0031561d711e000a20202020202001cf
02031df1509005040302071601061112
1513141f2023091f0783010000023a80
1871382d40582c450055502100001e01
1d8018711c1620582c25005550210000
9e011d007251d01e206e285500555021
00001e8c0ad08a20e02d10103e960055
50210000180000000000000000000000
0000000000000000000000000000009d
BorderDimensions:
SignalFormat: DisplayPort
supported: DisplayPort
2560x1440 (0x290) 241.5MHz +HSync -VSync *current +preferred
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.8KHz
v: height 1440 start 1443 end 1448 total 1481 clock 60.0Hz
1920x1200 (0x291) 193.2MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.6KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.9Hz
1920x1080 (0x281) 148.5MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.5KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.0Hz
1920x1080 (0x292) 148.3MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.4KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.9Hz
1920x1080 (0x293) 148.5MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.0Hz
1920x1080 (0x294) 74.2MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.0KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.0Hz
1920x1080 (0x295) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.8KHz
v: height 1080 start 1084 end 1094 total 1124 clock 30.0Hz
1920x1080 (0x296) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.7KHz
1920x1080 (0x297) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.1KHz
v: height 1080 start 1084 end 1094 total 1124 clock 25.0Hz
1680x1050 (0x282) 146.2MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.3KHz
v: height 1050 start 1053 end 1059 total 1089 clock 60.0Hz
1600x1200 (0x283) 162.0MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.0KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.0Hz
1280x1024 (0x284) 135.0MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 80.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.0Hz
1280x1024 (0x285) 108.0MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 64.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.0Hz
1280x800 (0x286) 83.5MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.7KHz
v: height 800 start 803 end 809 total 831 clock 59.8Hz
1280x720 (0x298) 74.2MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.0KHz
v: height 720 start 725 end 730 total 750 clock 60.0Hz
1280x720 (0x299) 74.2MHz +HSync +VSync
v: height 720 start 725 end 730 total 750 clock 59.9Hz
1280x720 (0x29a) 74.2MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.5KHz
v: height 720 start 725 end 730 total 750 clock 50.0Hz
1152x864 (0x287) 108.0MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.5KHz
v: height 864 start 865 end 868 total 900 clock 75.0Hz
1024x768 (0x288) 78.8MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.0KHz
v: height 768 start 769 end 772 total 800 clock 75.0Hz
1024x768 (0x289) 65.0MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz
v: height 768 start 771 end 777 total 806 clock 60.0Hz
800x600 (0x28a) 49.5MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.9KHz
v: height 600 start 601 end 604 total 625 clock 75.0Hz
800x600 (0x28b) 40.0MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz
v: height 600 start 601 end 605 total 628 clock 60.3Hz
720x576 (0x29b) 27.0MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.2KHz
v: height 576 start 581 end 586 total 625 clock 50.0Hz
720x576 (0x29c) 13.5MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.6KHz
v: height 576 start 580 end 586 total 624 clock 25.0Hz
720x480 (0x29d) 27.0MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.5KHz
v: height 480 start 489 end 495 total 525 clock 59.9Hz
720x480 (0x29e) 13.5MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.7KHz
v: height 480 start 488 end 494 total 524 clock 30.0Hz
640x480 (0x28c) 31.5MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.5KHz
v: height 480 start 481 end 484 total 500 clock 75.0Hz
640x480 (0x28d) 25.2MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz
v: height 480 start 490 end 492 total 525 clock 59.9Hz
640x480 (0x29f) 25.2MHz -HSync -VSync
DP-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x2a0
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
Here is the output without the code tag:
Identifier: 0x27b
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: VGA
supported: VGA
ConnectorType: VGA
Identifier: 0x27c
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
EDID:
BorderDimensions:
SignalFormat: LVDS
supported: LVDS
Identifier: 0x27f
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
Identifier: 0x280
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
Identifier: 0x28e
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
Identifier: 0x28f
Timestamp: 22192
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
filter:
EDID:
BorderDimensions:
Identifier: 0x2a0
Timestamp: 22192
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
BorderDimensions:
Sorry, I should have noticed from your post title: the NVS 5200M is a Fermi (GF108) GPU. DisplayPort 1.2 requires GF119 or Kepler.
Thanks. Everything is clear now.
LeviM
October 22, 2013, 7:29pm
6
I know that has been a few months, but the nvs for notebooks page indicates up to 3 external displays for the 5200M, and the newer NVS products for desktop explicitly state that they support DisplayPort 1.2 with MST.
Can we clarify whether the NVS 5200M and the NVS 5400M support DisplayPort 1.2 with Multi-Stream Transport (MST)? I am attempting to buy a laptop that will support MST and it is incredibly painful to know which models support it, and many OEM vendors are not familiar with this particular technology so asking them is always a dead-end and painful.
The NVS 5200M and 5400M definitely do not support DP 1.2. I would suggest contacting sales & marketing to find the right product for your needs.
LeviM
October 25, 2013, 3:38pm
8
It is good to know that the NVIDIA NVS 5200M and the NVIDIA NVS 5400M do not support DisplayPort 1.2 with Multi-Stream Transport (MST).
How can I contact sales and marketing at NVIDIA for the USA? I can’t seem to find any links on the website that would lead me there. Should I just use the general contact form ?
Seems to me the issue here is the DP 1.2 not the MST. If its DP 1.1 it wont have enough bandwidth to run two displays at 2560x1440 (or really at 1.1 it would be maxing the bandwidth). Does the xorg.log say the DFP link is 480 Mhz (dp 1.1) or 960 Mhz (1.2)?
I don’t see anywhere on that tech page that says its DP 1.2.
Sadly not all kepler is DP 1.2 either. I was kind of sad to find out the DP in my macbook pro retina was only 1.1 when (gt 650m) when a desktop gtx 650 or 670 are dp 1.2. Just because the desktop model is 1.2 doesn’t mean the mobile version is.
EDIT:
So I found a pastebin of someone with a 5200M:
[ 14826.394] (–) NVIDIA(0): DFP-3: Internal Single Link TMDS
[ 14826.394] (–) NVIDIA(0): DFP-4: 480.0 MHz maximum pixel clock
[ 14826.394] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 14826.394] (–) NVIDIA(0): DFP-5: 480.0 MHz maximum pixel clock
[ 14826.394] (–) NVIDIA(0): DFP-5: Internal DisplayPort
So it looks like DP 1.1 to me. I would think you could run one at 2560x1440 and one at 1920x1080 or something or maybe both at 2560x1440 at a lower refresh rate with custom modes and stuff? Even at reduced blanking 2560x1440@60h is 241.5 Mhz so two would be 483 Mhz (just above the 480 Mhz display port 1.1 max).
