I am daisy chaining two monitors using DP port on RTX5070Ti. After Bootup and login only second screen is functional. First screen remains black. Dmesg logs say [ 18.825431] [drm:nv_drm_dev_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to add connector for NvKmsKapiDisplay 0x00000800 [ 28.913577] [drm:nv_drm_dev_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to get dynamic displays [ 39.017579] [drm:nv_drm_handle_dynamic_display_connected [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to add encoder for NvKmsKapiDisplay 0x00000001
I have set drm modeset 1. However, unplugging and changing DP port on GPU fixes the issue.
Bug report after changing port
@swarankar.ani24 it looks like your GPU was failing to initialize correctly.
2025-10-26T13:15:28.146151-04:00 arthavpc kernel: NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2c05)
2025-10-26T13:15:28.146153-04:00 arthavpc kernel: NVRM: installed in this system requires use of the NVIDIA open kernel modules.
2025-10-26T13:15:28.146153-04:00 arthavpc kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:886)
2025-10-26T13:15:28.146154-04:00 arthavpc kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Looking earlier in the logs, it looks like the nouveau kernel module is being loaded and interfering with the initialization of the out-of-tree NVIDIA kernel driver, leading to the experience you are seeing.
[ 6.540771] nouveau 0000:01:00.0: unknown chipset (1b3000a1)
Could you get rid of the second line in blacklist-nouveau.conf and try rebuilding your initramfs on your distribution? According to the logs, nouveau seems to be loading.
I’m seeing the same problem with daisy chained monitors on EndeavorOS (Arch) with an RTX 3070 and have never had nouveau installed.
From dmesg:
[ 17.394678] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Failed to add connector for NvKmsKapiDisplay 0x00001000
[ 27.482679] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Failed to get dynamic displays
[ 27.544844] [drm] Initialized nvidia-drm 0.0.0 for 0000:0a:00.0 on minor 1
[ 27.561365] Console: switching to colour dummy device 80x25
[ 27.569591] nvidia 0000:0a:00.0: vgaarb: deactivate vga console
[ 27.731716] fbcon: nvidia-drmdrmfb (fb0) is primary device
[ 27.793117] Console: switching to colour frame buffer device 240x67
[ 30.818682] [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Flip event timeout on head 0
[ 30.820492] nvidia 0000:0a:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
Funnily enough, switching to a different DP port works until I need to reboot.
When I live boot from a USB with 570.124.04 version drivers I have no issues with my setup. Reading similar reports of the same issue elsewhere, it appears to have been an issue since at least 575 drivers:
I tried doing that. Unfortunately, I couldn’t even see any login screen post boot. Just black screen.
Above observation when booted with Display port MST on.
Thanks for getting back to me. I’m not sure what the “repro state” is (reproduced state?), but I’ve generated two bug reports and attached them here.
In the “reproduced state” the first monitor in the daisy chain receives no display port output.
In the “corrected state” I moved the display port connection to a different slot on the RTX3070 at the 5 minute mark, at that point the first display in the daisy chain started working again.
I did have a look through the open source kernel and noticed this commit, which is in the area reported in the dmesg log. Could this be the cause?
I believe nvidia drm modeset was set to 1 in the initial bug reports I added but I can try and attach again. The issue is still there on driver version 580.95.05
Can confirm the issue, got the same problem. GPU → Monitor 1 (Black) → Monitor 2 (gets Images). I need to cut off the connection between Monitor 1 and Monitor 2 while booting to make sure Monitor 1 gets Images. After then, I can replug the DP Cable to Monitor 2 and both Monitors get images (until next reboot). Using Ubuntu latest kernel with Wayland.
Unplugging the cable while the OS Is running on Monitor 2 doesn’t fix the issue on Monitor 1, as it doesn’t get detected in any way (until I use my manual fix described above).
Also, it is a Nvidia-driver issue, as using xserver-xorg-video-nouveau fixes the issue.
While booting, I’m also getting the Ubuntu loading screen with the xorg-driver and with Nvidia not. I need to wait for a few seconds (after I wiggled my mouse and pressed some keys on my keyboard) until Monitor 2 gets some images with Nvidia (when on login screen).
Upgraded to nvidia open driver 590.48.01 and kernel 6.18.2-arch2-1.
I’m seeing the same issue (as expected). I’ve attached the result of nvidia-bug-report.sh for the reproduced state again here.
