Need help getting two daisy-chained Dell U2415 displayport monitors to work properly with a Titan X graphics card on Ubuntu.
Current Configuration:
- Fresh install of Ubuntu 18.04.2 LTS on a Dell Precision T7910 workstation.
- Titan X graphics card. I plan to use this for deep learning but also need it to drive the dual monitors.
- Default Gnome desktop that comes standard with Ubuntu Desktop.
- Replaced Ubuntu's Nouveau graphics driver with Nvidia's proprietary nvidia-driver-390. Tried Nvidia 430 driver from apt repository ppa:graphics-drivers, but it causes the 2nd display to flicker very badly.
- Two Dell U2415 monitors configured in a displayport daisy chain. 1st monitor (one connected directly to the graphics card) is set to displayport 1.2 enabled. The 2nd monitor (2nd and last monitor in the displayport daisy chain) is set to displayport 1.2 disabled.
When the desktop starts, it only shows on the primary monitor. I have to run xset dpms force off
to force the monitors into sleep state and then move the mouse to wake them up and both monitors become active. However, one of the monitors runs at a very low resolution (640x480) while the other runs at the full resolution (1920x1200). A screenshot of the Nvidia X Settings can be found here https://flic.kr/p/2g6VjUW.
The first monitor is detected as “NVIDIA” with resolution 640x480 (the only options under resolution are Off, Auto, and 640x480). The second monitor is correctly detected as “DELL U2415” with resolution 1920x1200. Here is the output of the xrandr command. DP-0.8 is the first monitor in the daisy chain and DP-0.1 is the second.
Screen 0: minimum 8 x 8, current 2560 x 1200, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DP-0.1 connected 1920x1200+640+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 59.95*+ 59.88
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98
1600x1200 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0.8 connected primary 640x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
640x480 59.94*+
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-0.1.8 disconnected (normal left inverted right x axis y axis)
At this point, there was no xorg.conf file or monitors.xml file anywhere on the machine. I saved the X configuration file from Nvidia X Settings application. The saved /etc/X11/xorg.conf file is as follows.
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 390.77 (buildd@lcy01-amd64-022) Thu Sep 6 07:51:39 UTC 2018
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "NVIDIA"
HorizSync 31.5 - 31.5
VertRefresh 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX TITAN X"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2.8"
Option "metamodes" "DP-0.8: nvidia-auto-select +0+0, DP-0.1: nvidia-auto-select +640+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I see only one “monitor” section in this xorg.config. Why doesn’t it list the 2nd monitor?
In any case, how can I have the nvidia card properly detect both monitors as Dell U2415 along with the 1920x1200 resolution?
This same daisy-chained displayport monitor setup works fine with Windows 10. Both monitors are identical except the 1st one has displayport 1.2 (MST) enabled and the 2nd has it disabled. I can’t figure out why the nvidia driver is detecting the 1st monitor as NVIDIA with very low resolution and the 2nd monitor as DELL 2415 with the correct resolution - 1920x1200.
