bizmate
February 13, 2023, 1:13pm
1
In the last couple of days my two monitor setup stopped working, where the second monitor switches off, does not render. Now i am just seeing a black screen with a cursor.
I have tried downgrading, reinstalling the driver and also explicitly disabling nouveau but nothing makes a difference. I also removed the latest OEM kernel 6.0
GPU :
09:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU106 [GeForce RTX 2070] [10de:1f02] (rev a1) (prog-if 00 [VGA controller])
Output of dmesg | grep nvidia
[ 8.610542] kernel: nvidiafb 0000:09:00.0: BAR 3: can't reserve [mem 0xe0000000-0xe1ffffff 64bit pref]
[ 8.610544] kernel: nvidiafb: cannot request PCI regions
[ 8.800790] kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input14
[ 8.800843] kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input15
[ 8.800883] kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input16
[ 8.800919] kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input17
[ 8.800963] kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input18
[ 8.801002] kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input19
[ 8.801041] kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input20
[ 8.874116] kernel: audit: type=1400 audit(1676286052.660:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1137 comm="apparmor_parser"
[ 8.874118] kernel: audit: type=1400 audit(1676286052.660:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1137 comm="apparmor_parser"
[ 9.642696] kernel: nvidia-gpu 0000:09:00.3: i2c timeout error e0000000
lsb_release -a
|Description:|Ubuntu 22.04.1 LTS|
|Release:|22.04|
uname -r
5.15.0-56-lowlatency
Can you please suggest what else I can try to unblock the syste?
generix
February 13, 2023, 2:36pm
2
Please blacklist nvidiafb, that’s no part of the nvidia driver and is blocking it.
Looking at your bug report log in the other thread about your monitor issues, this looks like a cable/monitor issue. The stable monitor runs at 165MHz, the unstable at 300MHz. It sometimes vanishes completely, sometimes it’s there but the edid can’t be read. Please swap cables between the monitors and check whether the issue moves with it.
Furthermore, you seem to have some desktop plugin running that’s hammering the xserver with xrandr queries every second. Rather find and disable it.
bizmate
February 13, 2023, 3:27pm
3
hi generix
thank you for the reply. Unfortunately blacklisting nvidiafb makes no difference…
this is the output from my last boot dmesg logs
cat /var/log/dmesg | grep -i nvidia
[ 8.155066] kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input14
[ 8.155105] kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input15
[ 8.155125] kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input16
[ 8.155146] kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input17
[ 8.155174] kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input18
[ 8.155194] kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input19
[ 8.155221] kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input20
[ 8.274430] kernel: audit: type=1400 audit(1676301524.059:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1125 comm="apparmor_parser"
[ 8.274432] kernel: audit: type=1400 audit(1676301524.059:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1125 comm="apparmor_parser"
[ 9.044788] kernel: nvidia-gpu 0000:09:00.3: i2c timeout error e0000000
the blacklisting works as you can there is no output from nvidiafb anymore and the /etc/modprobe.d/blacklist-nvidiafb.conf file is in place
I have also reinstalled the driver version 525 and run updateramfs for all kernels … still stuck.
Any other idea on what to look into?
generix
February 13, 2023, 5:02pm
4
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
bizmate
February 13, 2023, 6:19pm
5
generix
February 13, 2023, 6:31pm
6
There are no nvidia kernel modules installed. Please try reinstalling kernel headers
sudo apt install --reinstall linux-headers-$(uname -r)
and post the output of
dkms status
dpkg -l |grep nvidia
bizmate
February 13, 2023, 6:40pm
7
dkms status
nvidia/525.78.01, 5.15.0-60-generic, x86_64: installed
v4l2loopback/0.12.5, 5.15.0-43-generic, x86_64: installed
v4l2loopback/0.12.5, 5.15.0-60-generic, x86_64: installed
The above also shows some warning such as grep: /lib/modules/5.15.0-43-generic/build.config: no such file or directory
dpkg output in file
dpkgGrepNvidia.log (8.0 KB)
generix
February 13, 2023, 6:42pm
8
Since the dkms status now shows the nvidia modules as installed for your kernel, please reboot and check if the modules load.
bizmate
February 13, 2023, 6:56pm
9
lsmod | grep nvidia shows …
i2c_nvidia_gpu 16384 0
The UX window manager/monitors are still not loading. I get a cursor with a black screen and to access the shell i am still CTRL + ALT + F3 and login there.
generix
February 13, 2023, 8:45pm
10
Please create a new nvidia-bug-report.log.
bizmate
February 13, 2023, 8:59pm
11
generix
February 13, 2023, 9:07pm
12
You now booted into an old kernel 5.15.0-56, the correct one is 5.15.0-60. Please select that in grub.
bizmate
February 13, 2023, 9:21pm
13
Thank you. I am able to boot with the 60-generic kernel. I swapped monitors around and now they both work. For some reason they stopped working when connected with the other cables?
How do i identify really what is causing this?
Also you wrote earlier
“you seem to have some desktop plugin running that’s hammering the xserver with xrandr queries every second.”
Can you please point out where you spotted this from so i can further look into it?
generix
February 13, 2023, 9:54pm
14
In the xorg logs and in journal,
(journalctl -b -0 _COMM=Xorg)
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): LG Electronics W2486 (DFP-6): connected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): LG Electronics W2486 (DFP-6): Internal TMDS
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): LG Electronics W2486 (DFP-6): 165.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-5: disconnected
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
Sep 15 05:57:34 bizmate-i7 /usr/libexec/gdm-x-session[4584]: (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
repeated over and over. The xserver logs that whenever xrandr is run.
generix
February 13, 2023, 9:55pm
15
What kind of cables are those exactly? DP2HDMI?
bizmate
February 14, 2023, 2:51am
16
generix
February 14, 2023, 9:58am
17
I can only speculate. While the monitors are the same, they might have different firmware versions, thus using different connection speeds. One cable might be flakey so only works at the lower speed monitor. Another idea might be the connectors became dirty and just pulling out/plugging back in the cables made it work again.
