Hi guys!
There is MSI GE76 laptop with NVIDIA RTX3080 video card worked under the control of Ubuntu 20. Both displays: the main display of the laptop and the second display DELL 24 1920/1080 worked successfully. The second display is connected via DP2 (sometimes connected via HDMI - it also worked successfully).
After updating Ubuntu to the version 21, the NVIDIA drivers disappeared. In this case, the additional display stopped working. If I boot Windows - both monitors work, else in Ubuntu - only the main monitor worked.
I installed the Nvidia drivers 495, but still only the main monitor worked.
Then I turned off safe mode in BIOS and something interesting happened!)
Now only the second monitor is working (Dell 24 ин DP2), but on the main display we can see one line text on a black background.
I tried install GDM and Lightdm, i tried other versions Nvidia drivers, i tried command sudo prime-select nvidia, but it is the same result.
The current situation looks like this
https://monosnap.com/direct/OgFROES9KfRB0Fo1kbL7JJnG9dYDnu
Can you please tell me how to make both displays work again?
Other debug information.
Driver, display options and Prime profile
https://www.awesomescreenshot.com/image/17116201?key=27c679c007c9b6c1d487f9548cf8c0cc
Nvidia x server settings https://www.awesomescreenshot.com/image/17116241?key=3a0ab31b51db08303b04b3acfa78e866
Xandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00 + 60.00* 59.94 50.00 23.98
1600x1200 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
xrandr --verbose
DP-0 connected primary 1920x1080+0+0 (0x1bf) normal (normal left inverted right x axis y axis) 527mm x 296mm
Identifier: 0x1bd
Timestamp: 126830
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
CTM: -26997632 0 1461765 0 9823659 -2147483648 1354350 -2147483648 4555181 1 6089007 0 661164 -2147483648 3539183 -2147483648
17386285 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
EDID:
00ffffffffffff0010ace7404c323934
0c1b0104a5351e783aee95a3544c9926
0f5054a54b00714f8180a940d1c00101
010101010101023a801871382d40582c
45000f282100001e000000ff00354b39
594437334e3439324c0a000000fc0044
454c4c205532343137480a20000000fd
00324b1e5311000a2020202020200133
02031df1509005040302071601061112
1513141f2023091f0783010000023a80
1871382d40582c25000f282100001e01
1d8018711c1620582c25000f28210000
9e011d007251d01e206e2855000f2821
00001e8c0ad08a20e02d10103e96000f
28210000180000000000000000000000
00000000000000000000000000000075
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
ConnectorNumber: 1
_ConnectorLocation: 1
non-desktop: 0
supported: 0, 1
1920x1080 (0x1be) 148.500MHz +HSync +VSync +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1bf) 148.500MHz +HSync +VSync *current
v: height 1080 start 1082 end 1087 total 1125 clock 60.00Hz
1920x1080 (0x1c0) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c1) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x1c2) 74.180MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1600x1200 (0x1c3) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1280x1024 (0x1c4) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c5) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x720 (0x1c6) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c7) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1c8) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1152x864 (0x1c9) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1ca) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1cb) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1cc) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1cd) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1ce) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1cf) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d0) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d1) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d2) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
Identifier: 0x1d3
Timestamp: 126830
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 1
non-desktop: 0
supported: 0, 1
Identifier: 0x1d4
Timestamp: 126830
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
Identifier: 0x1d5
Timestamp: 126830
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 2
non-desktop: 0
supported: 0, 1
Identifier: 0x1d6
Timestamp: 126830
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorType: Panel
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
Identifier: 0x1d7
Timestamp: 126830
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
lspci -k
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
DeviceName: Onboard - Other
Subsystem: Micro-Star International Co., Ltd. [MSI] 10th Gen Core Processor Host Bridge/DRAM Registers
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 02)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
DeviceName: Onboard - Video
Subsystem: Micro-Star International Co., Ltd. [MSI] CometLake-H GT2 [UHD Graphics]
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake PCH Thermal Controller
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake USB 3.1 xHCI Host Controller
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
Subsystem: Intel Corporation Comet Lake PCH Shared SRAM
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake PCH Serial IO I2C Controller
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.2 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #2
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake HECI Controller
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1b.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #17 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Device 06b4 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Device 06b6 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device 06b7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake LPC Controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
DeviceName: Onboard - Sound
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake PCH cAVS
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake PCH SMBus Controller
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GA104 High Definition Audio Controller
02:00.0 USB controller: ASMedia Technology Inc. ASM3242 USB 3.2 Host Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] ASM3242 USB 3.2 Host Controller
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Kernel driver in use: nvme
Kernel modules: nvme
04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
05:00.0 Ethernet controller: Intel Corporation Device 3101 (rev 03)
Subsystem: Intel Corporation Device 0000
Kernel driver in use: igc
Kernel modules: igc
06:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
Subsystem: Micro-Star International Co., Ltd. [MSI] RTS525A PCI Express Card Reader
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 6 associated providers: 0 name:NVIDIA-0
