the bug report:
nvidia-bug-report.log.gz (558.2 KB)
The system setup is as follows:
- OS: Ubuntu 22.04
- GPU: RTX 3080 LHR
- nvidia driver: 525.60.13 (installed using “software & updates → additional driver”)
- monitor 1: 2560x1080 LG 29WP500 connected with HDMI: working fine :)
- monitor 2: 2560x1080 LG 29WP500 connected with HDMI (monitor) to DisplayPort (GPU) : not fine :(
- monitor 3: 2560x1080 LG 25UM58-P connected with HDMI (monitor) to DisplayPort (GPU): not fine :(
So when I run xrandr I get:
Screen 0: minimum 8 x 8, current 5560 x 1920, maximum 32767 x 32767
HDMI-0 connected primary 2560x1080+1920+0 (normal left inverted right x axis y axis) 798mm x 334mm
2560x1080 59.98 + 74.99* 50.00
3840x2160 29.97 25.00 23.98
2560x1440 59.95
1920x1080 75.00 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1080x1920+4480+0 right (normal left inverted right x axis y axis) 673mm x 284mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
1680x1050 59.95
1600x900 60.00
1280x800 59.81
1152x864 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
And the two DisplayPort screens don’t show 2560x1080.
So I try to add the modelines:
$ cvt 2560 1080
# 2560x1080 59.98 Hz (CVT) hsync: 67.17 kHz; pclk: 230.00 MHz
Modeline "2560x1080_60.00" 230.00 2560 2720 2992 3424 1080 1083 1093 1120 -hsync +vsync
$ xrandr --newmode "2560x1080_60.00" 230.00 2560 2720 2992 3424 1080 1083 1093 1120 -hsync +vsync
xrandr --addmode DP-3 "2560x1080_60.00"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 45
Current serial number in output stream: 46
So I added the HorizSync and VertRefresh to the xorg.conf file:
$ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 525.60.13
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "DP-1"
EndSection
and it still wouldn’t let me add my desired resolution.
and I tried to set the resolution through ubuntu’s display settings as well as the nvidia settings app and I had no success there either.
There are two monitors that are identical, just one is HDMI and another is displayport. These are their EDIDs:
monitor 1 (HDMI):
00 ff ff ff ff ff ff 00 1e 6d 70 77 00 d4 01 00 09 20 01 03 80 50 22 78 ea 54 75 a5 57 52 9f 25 0a 50 54 25 6b 00 71 40 81 80 81 c0 a9 c0 b3 00 d1 c0 81 00 d1 cf cd 46 00 a0 a0 38 1f 40 30 20 3a 00 1e 4e 31 00 00 1a 02 3a 80 18 71 38 2d 40 58 2c 45 00 1e 4e 31 00 00 1e 00 00 00 fd 00 38 4b 1e 5a 18 01 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 47 20 55 4c 54 52 41 57 49 44 45 0a 01 85 02 03 31 f1 23 09 07 07 4b 10 04 03 01 1f 13 59 12 5d 5e 5f 83 01 00 00 6d 03 0c 00 10 00 b8 3c 20 00 60 01 02 03 e3 05 c0 00 e6 06 05 01 4a 4a 56 29 59 00 a0 a0 38 27 40 30 20 3a 00 1e 4e 31 00 00 1a 56 5e 00 a0 a0 a0 29 50 30 20 35 00 1e 4e 31 00 00 1a 00 00 00 ff 00 32 30 39 4e 54 41 42 33 48 38 30 38 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a8
monitor 2 (DisplayPort):
00 ff ff ff ff ff ff 00 1e 6d 70 77 f9 d3 01 00 09 20 01 03 80 50 22 78 ea 54 75 a5 57 52 9f 25 0a 50 54 25 6b 00 71 40 81 80 81 c0 a9 c0 b3 00 d1 c0 81 00 d1 cf cd 46 00 a0 a0 38 1f 40 30 20 3a 00 1e 4e 31 00 00 1a 02 3a 80 18 71 38 2d 40 58 2c 45 00 1e 4e 31 00 00 1e 00 00 00 fd 00 38 4b 1e 5a 18 01 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 47 20 55 4c 54 52 41 57 49 44 45 0a 01 8d 02 03 31 f1 23 09 07 07 4b 10 04 03 01 1f 13 59 12 5d 5e 5f 83 01 00 00 6d 03 0c 00 10 00 b8 3c 20 00 60 01 02 03 e3 05 c0 00 e6 06 05 01 4a 4a 56 29 59 00 a0 a0 38 27 40 30 20 3a 00 1e 4e 31 00 00 1a 56 5e 00 a0 a0 a0 29 50 30 20 35 00 1e 4e 31 00 00 1a 00 00 00 ff 00 32 30 39 4e 54 54 51 33 48 38 30 31 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8d
and when I put them in edidreader which parses the values, I get just about identical information except for some checksums. Furthermore, the monitor that doesn’t show the 2560x1080 resolution, has the information there.
I also connected the PC to someone else’s set up with 3 3440x1440 monitors and everything was working well. The only difference being those 3 monitors had both HDMI and DisplayPort connectors at the back so there was no HDMI-DisplayPort transition happening.
With my setup and cables (3 LG, 1 HDMI-HDMI, 2 HDMI-DisplayPort) I was able to get the right resolutions as well using Nouveau but it was a little laggy and I couldn’t use some of my software so I’m back to the nvidia driver with pain-inducing resolutions.
So the way I see it, with all this, my guess is that the issue comes from the nvidia driver not being able to properly parse the data coming from the HDMI to displayport cables.
Is there anything I have missed? Any suggestions are very welcome, I’ve been trying to fix this for 2 days now.
