I am also more or less in a similar situation . i have NVS 810 with 8 x Mini-DP connected to 8 Monitors ( where 5 x Mini-DP to DP and 3 x Mini-DP to DVI )
Monitors Max Resolutions --all at 60Hz :
1920 x 1200 ( 2 x Dell U2412Mb 24 inch monitors )
1920 x 1080 ( 2 x Dell G2410t 24 inch monitors )
1920 x 1080 ( 1 x Dell P2412Hb 24 inch monitor )
1920 x 1080 ( 3 x HP E221 22 inch monitors )
When i connect the card to windows server 2012 R2 with 375.26 , all 8 monitors are detected and are not blank
When i move them to the UBUNTU 16.04.1 system with 375.26 , all 8 monitors are active but only 4 are live and the other 4 are blank even though they are active. The Blank monitors are on GPU# 1 ( 3 x Mini-DP to DVI and 1 x mini-DP to DP )
On UBUNTU 16.04.1 (Linux) when i run the command: nvidia-xconfig --query-gpu-info i get
Number of GPUs: 2
GPU #0:
UUID : GPU-a60fdc1e-8949-5b40-cbe4-2499f729f6ba
PCI BusID : PCI:10:0:0
Number of Display Devices: 4
Display Device 0 (TV-4):
EDID Name : DELL U2412M
Minimum HorizSync : 30.000 kHz
Maximum HorizSync : 83.000 kHz
Minimum VertRefresh : 50 Hz
Maximum VertRefresh : 61 Hz
Maximum PixelClock : 170.000 MHz
Maximum Width : 1920 pixels
Maximum Height : 1200 pixels
Preferred Width : 1920 pixels
Preferred Height : 1200 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 520 mm
Physical Height : 320 mm
Display Device 1 (TV-5):
Display Device 2 (TV-6):
EDID Name : HP E221
Minimum HorizSync : 24.000 kHz
Maximum HorizSync : 94.000 kHz
Maximum VertRefresh : 76 Hz
Maximum Height : 1080 pixels
Preferred Height : 1080 pixels
Physical Width : 500 mm
Physical Height : 290 mm
Display Device 3 (TV-7):
EDID Name : HP E221
GPU #1:
UUID : GPU-c6868dfd-a173-3b97-dc75-0e11d179f311
PCI BusID : PCI:12:0:0
Display Device 0 (TV-0):
EDID Name : DELL G2410
Minimum VertRefresh : 56 Hz
Physical Width : 530 mm
Physical Height : 300 mm
Display Device 1 (TV-1):
Display Device 2 (TV-2):
EDID Name : DELL P2412H
EDID Name : HP E221
I have tried Generating the /etc/X11/Xorg.conf file with several variations
nvidia-xconfig --enable-all-gpus
nvidia-xconfig --enable-all-gpus --seperate-x-screens
Even with all that i can’t not get the 4 other monitors to display anything they are blank even though they are being detected and lit up except they are blank but i can move the mouse cursor over the monitor screen and see it moving across the other 4 blank monitors .
Below is the /etc/X11/xorg.conf file i am using when i run the command nvidia-xconfig --enable-all-gpus --seperate-x-screens . Please help
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 375.26 (buildmeister@swio-display-x86-rhel47-01) Thu Dec 8 19:07:46 PST 2016
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
Screen 1 “Screen1” RightOf “Screen0”
Screen 2 “Screen2” Above “Screen1”
Screen 3 “Screen3” Above “Screen2”
Screen 4 “Screen4” RightOf “Screen2”
Screen 5 “Screen5” RightOf “Screen4”
Screen 6 “Screen6” Above “Screen5”
Screen 7 “Screen7” Above “Screen6”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor1”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor2”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor3”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor4”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor5”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor6”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “NVS 810”
BusID “PCI:10:0:0”
Screen 0
EndSection
Section “Device”
Identifier “Device1”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:10:0:0”
Screen 1
EndSection
Section “Device”
Identifier “Device2”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:10:0:0”
Screen 2
EndSection
Section “Device”
Identifier “Device3”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:10:0:0”
Screen 3
EndSection
Section “Device”
Identifier “Device4”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:12:0:0”
Screen 4
EndSection
Section “Device”
Identifier “Device5”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:12:0:0”
Screen 5
EndSection
Section “Device”
Identifier “Device6”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:12:0:0”
Screen 6
EndSection
Section “Device”
Identifier “Device7”
Driver “nvidia”
BoardName “NVS 810”
BusID “PCI:12:0:0”
Screen 7
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen1”
Device “Device1”
Monitor “Monitor1”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen2”
Device “Device2”
Monitor “Monitor2”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen3”
Device “Device3”
Monitor “Monitor3”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen4”
Device “Device4”
Monitor “Monitor4”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen5”
Device “Device5”
Monitor “Monitor5”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen6”
Device “Device6”
Monitor “Monitor6”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen7”
Device “Device7”
Monitor “Monitor7”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
What am i missing in trying to configure this monitors or make them all work with Nvidia NVS 810 ? Any help please . Have spent a few hours on this trying to make it work
