Some observation about DGX Spark usb ports
I have a USB 4 enclosure for 2280 M.2 SSD but speed was not consistant from one day to the next so I did some testing:
  1. Plug in the enclosure before DGX Spark power up
    2.. Plug in the enclosure after DGX Spark has powered up.
I test it with several other usb devices like usb to HDMI, keyboard, etc…
The IC in this USB 4 enclosure is : 2463 ASMedia Technology Inc
In scenario 1, the speed is always USB 2, 480MB
In scenario 2, the speed will go up to 2000MB.
If there is a speed issue regarding your USB devices, you might want to plug in your USB storage after DGX Spark has powered up.
Yes, I’ve had the same issue pretty consistently. I wish Nvidia would fix this bug. I can’t remember the last time I encountered a computer where the USB ports couldn’t consistently negotiate the proper connection speed:
> lsusb -t | grep Storage
    |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=uas, 480M
I don’t know if it’s useful info, but FWIW I ran the command above after a reboot because I have an external drive (Crucial X10, USB 3.2x2), but it doesn’t seem to have this issue:
danny@toad:~$ lsusb -t | grep Storage
    |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=uas, 20000M/x2
I am guessing that it depends on the chipset in the external USB enclosure. If you run lsusb -tvv, it might give us the chipset of your usb storage device.
Assuming that was aimed at me, this is what I see (to be clear, it’s not an enclosure, it’s just an external drive, Cruxial X10):
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 20000M/x2
    ID 1d6b:0003 Linux Foundation 3.0 root hub
    /sys/bus/usb/devices/usb2  /dev/bus/usb/002/001
        ID 0634:5607 Micron Technology, Inc.
        /sys/bus/usb/devices/2-1  /dev/bus/usb/002/002
I have connected 3 USB storage before powering on.
ID 174c:2364 ASMedia Technology Inc.
ID 152d:0581 JMicron Technology Corp. / JMicron USA Technology Corp.
I believe it depends on USB storage device. I have another USB storage with 3.2 gen 2x2 / ASMedia , but is couldn’t connect 20000M/x2.
The issue only appears after rebooting the machine with the device plugged in. If I unplug/replug, it negotiates back to the correct speed. Maybe there is an issue only with certain devices, but it does happen with the NVMe enclosure I’ve been trying to use.
Bus 006 Device 002: ID 1e91:de79 Other World Computing Express 1M2
Thanks. I guess Micron use their own chip and their driver people usually follow the spec more closely
It can be cable problem too so I will try to get some new cables and test it to give more feedback. I think it is a driver issue. Most of these chip has internal driver writting in embeded C, they might not test all scenario.
They might test some motherboards then call it a day.
Write code is easy, testing is hard.
