[ 65.885925] usb usb1-port3: disabled by hub (EMI?), re-enabling…
I happen to have the same error. USB1 (USB3.0) connects to a four port HUB3.0 and the USB2 (USB2.) connects to a WiFi module. Can you advice why the error appears ?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (zhigang@zhigang-VirtualBox) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #13 SMP PREEMPT Mon Jun 22 19:27:50 CDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb0000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefae000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb0000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 pcie_aspm=off pci=nomsi
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29252(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562256K/4159488K available (15294K kernel code, 2936K rwdata, 6592K rodata, 8576K init, 611K bss, 122096K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff80095f0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a12e008 ( 2937 KB)
[ 0.000000] .bss : 0xffffff800a12e008 - 0xffffff800a1c6f3c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.009921] Console: colour dummy device 80x25
[ 0.014588] console [tty0] enabled
[ 0.018098] bootconsole [uart8250] disabled
[ 0.022429] kmemleak: Kernel memory leak detector disabled
[ 0.022458] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.022480] pid_max: default: 32768 minimum: 301
[ 0.022940] Security Framework initialized
[ 0.023177] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023193] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024348] ftrace: allocating 47104 entries in 185 pages
[ 0.195544] sched-energy: CPU device node has no sched-energy-costs
[ 0.195580] ASID allocator initialised with 65536 entries
[ 0.232352] tegra-id: chipid=22117.
[ 0.232388] tegra-id: opt_subrevision=0.
[ 0.232410] Tegra Speedo/IDDQ fuse revision 4
[ 0.232420] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232433] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.232479] Tegra: CPU Speedo Value 2115, SoC Speedo Value 1996, GPU Speedo Value 2116
[ 0.232494] Tegra: CPU IDDQ Value 2564, SoC IDDQ Value 2820, GPU IDDQ Value 3435
[ 0.232521] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.232548] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.232571] DTB Build time: Jun 18 2020 18:04:02
[ 0.281317] CPU1: Booted secondary processor [411fd071]
[ 0.313231] CPU2: Booted secondary processor [411fd071]
[ 0.345192] CPU3: Booted secondary processor [411fd071]
[ 0.345278] Brought up 4 CPUs
[ 0.345344] SMP: Total of 4 processors activated.
[ 0.345363] CPU features: detected feature: 32-bit EL0 Support
[ 0.345638] CPU: All CPU(s) started at EL2
[ 0.345669] alternatives: patching kernel code
[ 0.354180] devtmpfs: initialized
[ 0.392556] Initilizing CustomIPI irq domain
[ 0.393010] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.393065] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.404599] pinctrl core: initialized pinctrl subsystem
[ 0.405303] OS set in device tree is not L4T.
[ 0.405801] regulator-dummy: no parameters
[ 0.406090] Initializing plugin-manager
[ 0.406215] Plugin module not found
[ 0.406457] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.407062] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.407571] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.408263] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.408706] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.409399] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.411552] node /plugin-manager/fragement@11 match with board >=3448-0002-300
[ 0.415114] NET: Registered protocol family 16
[ 0.416391] pstore: using zlib compression
[ 0.417128] console [pstore-1] enabled
[ 0.417146] pstore: Registered ramoops as persistent store backend
[ 0.417165] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.433336] cpuidle: using governor menu
[ 0.436745] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.438731] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[ 0.438778] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.441880] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.444156] Serial: AMBA PL011 UART driver
[ 0.444703] tegra_powergate_init: DONE
[ 0.444741] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.444774] DTB Build time: Jun 18 2020 18:04:02
[ 0.446790] Tegra reboot handler registered.
[ 0.451427] iommu: Adding device tegra-carveouts to group 0
[ 0.451604] platform tegra-carveouts: domain=ffffffc0f9bd9498 allocates as[0]=ffffffc0f94400a8
[ 0.452006] iommu: Adding device smmu_test to group 1
[ 0.452070] platform smmu_test: domain=ffffffc0f9bd96d8 allocates as[0]=ffffffc0f9440110
[ 0.452910] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.452987] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.453059] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.453083] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.453119] mc-err: mcerr ops are set to t21x
[ 0.463525] iommu: Adding device 70090000.xusb to group 2
[ 0.463851] iommu: Adding device 70006000.serial to group 3
[ 0.463955] platform 70006000.serial: domain=ffffffc0f94b1618 allocates as[0]=ffffffc0f9440178
[ 0.464402] iommu: Adding device 70006040.serial to group 4
[ 0.464693] iommu: Adding device 70006200.serial to group 5
[ 0.464936] iommu: Adding device sound to group 6
[ 0.464998] platform sound: domain=ffffffc0f94b1b58 allocates as[0]=ffffffc0f94401e0
[ 0.465682] iommu: Adding device 7000d400.spi to group 7
[ 0.465980] iommu: Adding device 7000d600.spi to group 8
[ 0.466333] iommu: Adding device 50000000.host1x to group 9
[ 0.466626] iommu: Adding device 54080000.vi to group 10
[ 0.467050] iommu: Adding device 54600000.isp to group 11
[ 0.467333] iommu: Adding device 54680000.isp to group 12
[ 0.467633] iommu: Adding device tegradc.0 to group 13
[ 0.467732] platform tegradc.0: domain=ffffffc0f94be918 allocates as[0]=ffffffc0f9440248
[ 0.471938] platform tegradc.0: IOVA linear map 0x0000000092cb0000(800000)
[ 0.472349] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.472647] iommu: Adding device 54340000.vic to group 14
[ 0.472877] iommu: Adding device 544c0000.nvenc to group 15
[ 0.473095] iommu: Adding device 54500000.tsec to group 16
[ 0.473321] iommu: Adding device 54100000.tsecb to group 17
[ 0.473554] iommu: Adding device 54480000.nvdec to group 18
[ 0.473759] iommu: Adding device 54380000.nvjpg to group 19
[ 0.474897] iommu: Adding device 57000000.gpu to group 20
[ 0.474968] platform 57000000.gpu: domain=ffffffc0f94cb798 allocates as[0]=ffffffc0f94402b0
[ 0.475054] platform 57000000.gpu: domain=ffffffc0f94cb798 allocates as[1]=ffffffc0f9440318
[ 0.475113] platform 57000000.gpu: domain=ffffffc0f94cb798 allocates as[2]=ffffffc0f9440380
[ 0.475173] platform 57000000.gpu: domain=ffffffc0f94cb798 allocates as[3]=ffffffc0f94403e8
[ 0.476063] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.476103] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.476133] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.476153] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.476171] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.529445] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.529481] tegra-pmc: Clear bootloader IO dpd settings
[ 0.529517] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.529602] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.529907] iommu: Adding device 70012000.se to group 21
[ 0.530788] iommu: Adding device 7000c000.i2c to group 22
[ 0.531128] iommu: Adding device 7000c400.i2c to group 23
[ 0.531458] iommu: Adding device 7000c500.i2c to group 24
[ 0.531778] iommu: Adding device 7000c700.i2c to group 25
[ 0.532110] iommu: Adding device 7000d000.i2c to group 26
[ 0.532422] iommu: Adding device 7000d100.i2c to group 27
[ 0.532717] iommu: Adding device sdhci-tegra.3 to group 28
[ 0.532791] platform sdhci-tegra.3: domain=ffffffc0f9540918 allocates as[0]=ffffffc0f9440450
[ 0.533409] iommu: Adding device sdhci-tegra.2 to group 29
[ 0.533478] platform sdhci-tegra.2: domain=ffffffc0f9540b58 allocates as[0]=ffffffc0f94404b8
[ 0.534520] iommu: Adding device 700d0000.xudc to group 30
[ 0.539122] vdd-ac-bat: 5000 mV
[ 0.539615] vdd-5v0-sys: 5000 mV
[ 0.540828] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.540898] vdd-5v0-hdmi: 5000 mV
[ 0.541448] vdd-1v8-sys: 1800 mV
[ 0.541915] vdd-fan: supplied by vdd-5v0-sys
[ 0.541970] vdd-fan: 5000 mV
[ 0.542480] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.542533] vdd-usb-vbus: 5000 mV
[ 0.543265] vdd-usb-vbus2: 5000 mV
[ 0.574142] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.576616] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.577854] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.577897] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.577947] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.578338] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.586663] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.587071] SCSI subsystem initialized
[ 0.587316] libata version 3.00 loaded.
[ 0.587567] usbcore: registered new interface driver usbfs
[ 0.587634] usbcore: registered new interface driver hub
[ 0.587736] usbcore: registered new device driver usb
[ 0.591789] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.594060] random: fast init done
[ 0.597528] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.598564] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.601255] vdd-ddr-1v1: 1150 mV
[ 0.605305] vdd-pre-reg-1v35: 1350 mV
[ 0.609246] vdd-1v8: 1800 mV
[ 0.613216] avdd-sys-1v2: 1200 mV
[ 0.617216] vdd-pex-1v0: 1050 mV
[ 0.617863] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.618432] max77620-ldo3: at 3100 mV
[ 0.621216] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.621816] max77620-ldo5: at 3100 mV
[ 0.625212] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.629216] avdd-1v05-pll: 1050 mV
[ 0.633211] avdd-io-hdmi-dp: 1050 mV
[ 0.635835] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.636153] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.636469] max77620 4-003c: max77620 probe successful
[ 0.638288] media: Linux media interface: v0.10
[ 0.638358] Linux video capture interface: v2.00
[ 0.639314] pps_core: LinuxPPS API ver. 1 registered
[ 0.639345] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.639387] PTP clock support registered
[ 0.642811] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.643692] Advanced Linux Sound Architecture Driver Initialized.
[ 0.644398] Bluetooth: Core ver 2.22
[ 0.644527] NET: Registered protocol family 31
[ 0.644548] Bluetooth: HCI device and connection manager initialized
[ 0.644576] Bluetooth: HCI socket layer initialized
[ 0.644598] Bluetooth: L2CAP socket layer initialized
[ 0.644661] Bluetooth: SCO socket layer initialized
[ 0.646419] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.646462] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.646524] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.646553] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.650541] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.651822] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.651911] vdd-3v3-sys: 3300 mV
[ 0.652196] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.656710] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.657224] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.657301] vdd-3v3-sd: 3300 mV
[ 0.658311] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.658369] avdd-io-edp-1v05: 1050 mV
[ 0.658806] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.658859] vdd-usb-hub-en: 5000 mV
[ 0.660242] camchar: rtcpu character device driver loaded
[ 0.661053] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.662377] clocksource: Switched to clocksource arch_sys_counter
[ 0.704095] VFS: Disk quotas dquot_6.6.0
[ 0.704274] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.704791] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.705203] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.705252] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.705546] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.705577] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.705609] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.705669] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.705696] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.705729] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.705751] nvmap_page_pool_init: Total RAM pages: 1009348
[ 0.705769] nvmap_page_pool_init: nvmap page pool size: 126168 pages (492 MB)
[ 0.705938] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.706268] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.707231] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.715606] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.716058] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.716337] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.716583] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.716794] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.717100] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.717120] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.717579] NET: Registered protocol family 2
[ 0.718612] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.718848] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.719394] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.719568] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.719669] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.720105] NET: Registered protocol family 1
[ 0.720920] RPC: Registered named UNIX socket transport module.
[ 0.720951] RPC: Registered udp transport module.
[ 0.720969] RPC: Registered tcp transport module.
[ 0.720987] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.721016] PCI: CLS 0 bytes, default 64
[ 0.721258] Trying to unpack rootfs image as initramfs…
[ 0.956795] Freeing initrd memory: 5356K
[ 0.966932] host1x 50000000.host1x: initialized
[ 0.968801] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.972168] audit: initializing netlink subsys (disabled)
[ 0.972267] audit: type=2000 audit(0.815:1): initialized
[ 0.973096] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.983307] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.984830] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.985676] 9p: Installing v9fs 9p2000 file system support
[ 0.989056] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.989242] io scheduler noop registered
[ 0.989544] io scheduler cfq registered (default)
[ 0.992521] gic 702f9000.agic: GIC IRQ controller registered
[ 0.995554] iommu: Adding device 702ef000.adsp to group 31
[ 1.004562] iommu: Adding device aconnect@702c0000:adsp_audio to group 32
[ 1.004742] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.005330] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x81c7414
[ 1.005362] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.007215] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.007393] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.007509] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.007727] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.007842] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.007953] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.008070] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.008182] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.008292] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.008402] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.014423] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.016177] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.018044] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.019355] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.019721] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.021076] Adding domain tsec-pd to PM domain host1x-pd
[ 1.023485] tegra-pcie 1003000.pcie: ----- add 320ms delay before rst
[ 1.027404] tsec 54500000.tsec: initialized
[ 1.028822] tsec 54100000.tsecb: initialized
[ 1.029562] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.033454] nvdec 54480000.nvdec: initialized
[ 1.034549] Adding domain vic03-pd to PM domain host1x-pd
[ 1.034755] Adding domain msenc-pd to PM domain host1x-pd
[ 1.034942] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.039039] falcon 54340000.vic: initialized
[ 1.040369] falcon 544c0000.nvenc: initialized
[ 1.041779] falcon 54380000.nvjpg: initialized
[ 1.046127] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=95
[ 1.046205] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.046256] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.046421] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.046570] display board info: id 0x0, fab 0x0
[ 1.046601] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.046623] tegra_cec 70015000.tegra_cec: probed
[ 1.046676] generic_infoframe_type: 0x87
[ 1.046835] tegradc tegradc.0: DT parsed successfully
[ 1.046894] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.047441] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.054494] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.059681] tegradc tegradc.0: probed
[ 1.059984] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.061095] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.061164] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.061757] kfuse 7000fc00.kfuse: initialized
[ 1.063528] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.064643] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.066158] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.066206] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.066828] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.068564] vdd-gpu: applied init 1000000uV constraint
[ 1.068605] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.069089] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.075861] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.076090] No Device Node present for smmu client: serial8250 !!
[ 1.076126] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.076218] iommu: Adding device serial8250 to group 33
[ 1.080231] console [ttyS0] disabled
[ 1.080488] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.125610] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.127762] tegra-pcie 1003000.pcie: ----- add 320ms delay before rst
[ 1.260550] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.260556] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.260561] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.260566] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.260571] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.260594] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.260657] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.260836] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.260890] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.261051] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.261059] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.261181] pci 0000:01:00.0: [12d8:2404] type 01 class 0x060400
[ 1.261308] pci 0000:01:00.0: supports D1 D2
[ 1.261311] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.261471] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.261605] pci 0000:02:01.0: [12d8:2404] type 01 class 0x060400
[ 1.261730] pci 0000:02:01.0: supports D1 D2
[ 1.261734] pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.261912] pci 0000:02:02.0: [12d8:2404] type 01 class 0x060400
[ 1.262035] pci 0000:02:02.0: supports D1 D2
[ 1.262039] pci 0000:02:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.262214] pci 0000:02:03.0: [12d8:2404] type 01 class 0x060400
[ 1.262336] pci 0000:02:03.0: supports D1 D2
[ 1.262340] pci 0000:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.262562] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.262572] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.262582] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.262699] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 1.262809] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 04
[ 1.262936] pci 0000:05:00.0: [1bcd:0120] type 00 class 0x010802
[ 1.262968] pci 0000:05:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.263301] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
[ 1.263309] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 05
[ 1.263317] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 05
[ 1.263434] pci 0000:06:00.0: [10ec:8168] type 00 class 0x020000
[ 1.263455] pci 0000:06:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.263480] pci 0000:06:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 1.263498] pci 0000:06:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.263604] pci 0000:06:00.0: supports D1 D2
[ 1.263607] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.263781] pci_bus 0000:06: busn_res: [bus 06-ff] end is updated to 06
[ 1.263870] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.263877] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 1.263882] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.263888] pci 0000:01:00.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.263893] pci 0000:02:03.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.263898] pci 0000:02:01.0: PCI bridge to [bus 03]
[ 1.263913] pci 0000:02:02.0: PCI bridge to [bus 04]
[ 1.263931] pci 0000:05:00.0: BAR 0: assigned [mem 0x13000000-0x13003fff 64bit]
[ 1.263948] pci 0000:02:03.0: PCI bridge to [bus 05]
[ 1.263955] pci 0000:02:03.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.263966] pci 0000:01:00.0: PCI bridge to [bus 02-05]
[ 1.263973] pci 0000:01:00.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.263984] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[ 1.263989] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.263999] pci 0000:06:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 1.264015] pci 0000:06:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 1.264029] pci 0000:06:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.264037] pci 0000:00:02.0: PCI bridge to [bus 06]
[ 1.264041] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.264047] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 1.264053] PCIE: ASPM not enabled
[ 1.264238] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.264242] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.264245] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
[ 1.264247] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 1.264250] pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
[ 1.264253] pci 0000:05:00.0: Signaling PME through PCIe PME interrupt
[ 1.264258] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.264428] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.264431] pci 0000:06:00.0: Signaling PME through PCIe PME interrupt
[ 1.264436] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.078864] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.078868] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 3.658501] console [ttyS0] enabled
[ 3.658898] Console: switching to colour frame buffer device 240x67
[ 3.663110] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.663341] serial-tegra 70006200.serial: RX in PIO mode
[ 3.663416] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.664143] [drm] Initialized
[ 3.694887] brd: module loaded
[ 3.698174] tegradc tegradc.0: fb registered
[ 3.705045] loop: module loaded
[ 3.708299] tegra_profiler: version: 1.141, samples/io: 48/28
[ 3.708468] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 3.708494] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 3.708843] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.708851] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.734568] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.734571] Extcon AUX1(HDMI) enable
[ 3.753624] tegra_profiler: auth: init
[ 3.757883] THERMAL EST: found 2 subdevs
[ 3.761828] THERMAL EST num_resources: 0
[ 3.765759] [THERMAL EST subdev 0]
[ 3.769169] [THERMAL EST subdev 1]
[ 3.770725] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 3.783158] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.792120] THERMAL EST: thz register success.
[ 3.796676] THERMAL EST: end of probe, return err: 0
[ 3.802327] sd: No Scsi addr parsed to reserve index
[ 3.807337] hisi_sas: driver version v1.6
[ 3.811987] nvme nvme0: pci function 0000:05:00.0
[ 3.816725] nvme 0000:05:00.0: enabling device (0000 → 0002)
[ 3.823293] libphy: Fixed MDIO Bus: probed
[ 3.828041] tun: Universal TUN/TAP device driver, 1.6
[ 3.833108] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.843106] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.848955] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.854935] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.862446] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.868091] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.875931] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.881908] tegradc tegradc.0: blank - powerdown
[ 3.881911] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.881913] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.882599] r8168 0000:06:00.0: enabling device (0000 → 0003)
[ 3.882616] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.882675] r8168 0000:06:00.0: no MSI. Back to INTx.
[ 3.903843] r8168 0000:06:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.903920] r8168 0000:06:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:eb:de from device tree
[ 3.904305] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.904336] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.904717] PPP generic driver version 2.4.2
[ 3.904857] PPP BSD Compression module registered
[ 3.904859] PPP Deflate Compression module registered
[ 3.904873] PPP MPPE Compression module registered
[ 3.904877] NET: Registered protocol family 24
[ 3.904926] usbcore: registered new interface driver r8152
[ 3.904967] usbcore: registered new interface driver asix
[ 3.905007] usbcore: registered new interface driver ax88179_178a
[ 3.905041] usbcore: registered new interface driver cdc_ether
[ 3.905077] usbcore: registered new interface driver net1080
[ 3.905110] usbcore: registered new interface driver cdc_subset
[ 3.905143] usbcore: registered new interface driver zaurus
[ 3.905185] usbcore: registered new interface driver cdc_ncm
[ 3.905315] VFIO - User Level meta-driver version: 0.3
[ 3.906259] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.906269] ehci-pci: EHCI PCI platform driver
[ 3.906313] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.906319] ohci-pci: OHCI PCI platform driver
[ 3.906380] ohci-platform: OHCI generic platform driver
[ 3.908171] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.908705] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.909741] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d2c00 id
[ 3.911206] usbcore: registered new interface driver uas
[ 3.911255] usbcore: registered new interface driver usb-storage
[ 3.911335] usbcore: registered new interface driver usbserial
[ 3.912166] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 3.912195] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.912211] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 3.912924] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 3.912958] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.913109] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.913114] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.913118] usb usb1: Product: xHCI Host Controller
[ 3.913122] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.913125] usb usb1: SerialNumber: 70090000.xusb
[ 3.913543] hub 1-0:1.0: USB hub found
[ 3.913575] hub 1-0:1.0: 5 ports detected
[ 3.914057] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.914066] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 3.914139] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.914231] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.914236] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.914240] usb usb2: Product: xHCI Host Controller
[ 3.914243] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.914246] usb usb2: SerialNumber: 70090000.xusb
[ 3.914645] hub 2-0:1.0: USB hub found
[ 3.914677] hub 2-0:1.0: 4 ports detected
[ 3.915996] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.916912] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.916921] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.916942] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.917153] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.917596] mousedev: PS/2 mouse device common for all mice
[ 3.917657] usbcore: registered new interface driver xpad
[ 3.918704] rtc-m41t93 spi1.0: rtc core: registered rtc-m41t93 as rtc0
[ 3.927038] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 3.927042] Extcon AUX1(HDMI) disable
[ 3.932131] nvme0n1: p1
[ 3.950435] max77686-rtc max77620-rtc: /aliases ID 0 not available
[ 3.958421] tegradc tegradc.0: unblank
[ 3.998161] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 3.998219] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 3.999235] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 3.999242] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.014445] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 4.014507] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 4.033821] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.033824] Extcon AUX1(HDMI) enable
[ 4.034199] tegradc tegradc.0: sync windows ret = 250
[ 4.047556] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 4.048557] tegra_rtc 7000e000.rtc: /aliases ID 1 not available
[ 4.049842] rtc rtc2: alarm rtc device
[ 4.049854] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc2
[ 4.049871] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 4.050266] i2c /dev entries driver
[ 4.052105] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 4.053999] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 4.054003] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 4.054294] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.054306] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 4.054314] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 4.054476] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.054485] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 4.054491] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 4.054635] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.054643] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 4.054647] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 4.054816] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 4.055381] tegra_aotag tegra-aotag: Registering sensor 0
[ 4.055425] tegra_aotag tegra-aotag: Invalid temp readout
[ 4.055446] tegra_aotag tegra-aotag: Invalid temp readout
[ 4.055462] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 4.055470] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 4.056196] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.056210] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 4.056352] tegra_aotag tegra-aotag: Invalid temp readout
[ 4.056374] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 4.056697] parse_throttle_dt_data: Num cap clks = 6
[ 4.056700] parse_throttle_dt_data: clk=cclk_g type=2
[ 4.056707] parse_throttle_dt_data: clk=gpu type=4
[ 4.056725] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 4.056740] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 4.056757] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 4.056760] parse_throttle_dt_data: clk=emc type=3
[ 4.057138] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.057229] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.057338] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.057910] FAN dev name: pwm-fan
[ 4.057956] FAN:gpio request success.
[ 4.058007] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.058239] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.058355] pwm_fan_driver pwm-fan: fan tach request irq success
[ 4.058378] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.058455] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.058460] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.058464] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.058468] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.058472] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.058476] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.058480] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.058484] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.058488] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.058492] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.059094] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 4.059360] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 4.060181] device-mapper: uevent: version 1.0.3
[ 4.060637] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.063282] tegra210-cpufreq cpufreq: probe()…completed
[ 4.064124] sdhci: Secure Digital Host Controller Interface driver
[ 4.064125] sdhci: Copyright(c) Pierre Ossman
[ 4.064127] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.064492] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 4.069298] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 4.072291] tegra-se 70012000.se: tegra_se_probe: complete
[ 4.072797] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.073860] usbcore: registered new interface driver usbhid
[ 4.073861] usbhid: USB HID core driver
[ 4.074762] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 4.075841] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 4.077643] nvpmodel: initialized successfully
[ 4.078640] usbcore: registered new interface driver snd-usb-audio
[ 4.078700] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.078705] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.078723] iommu: Adding device snd-soc-dummy to group 34
[ 4.096640] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.104817] OPE platform probe
[ 4.104908] OPE platform probe successful
[ 4.105179] OPE platform probe
[ 4.105259] OPE platform probe successful
[ 4.114386] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 4.122393] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 4.137733] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.137852] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.137974] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.138089] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.138210] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.138324] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.138459] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.138573] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.138683] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.138798] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.150538] u32 classifier
[ 4.150540] Actions configured
[ 4.150610] Initializing XFRM netlink socket
[ 4.151316] NET: Registered protocol family 10
[ 4.152031] NET: Registered protocol family 17
[ 4.152043] NET: Registered protocol family 15
[ 4.152115] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.152159] Bluetooth: RFCOMM socket layer initialized
[ 4.152176] Bluetooth: RFCOMM ver 1.11
[ 4.152181] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.152186] Bluetooth: HIDP socket layer initialized
[ 4.152203] 9pnet: Installing 9P2000 support
[ 4.152239] Key type dns_resolver registered
[ 4.169225] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.172055] Registered cp15_barrier emulation handler
[ 4.172106] Registered setend emulation handler
[ 4.173223] registered taskstats version 1
[ 4.173577] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 4.173918] Adding domain ve2-pd to PM domain host1x-pd
[ 4.174159] Adding domain ve-pd to PM domain host1x-pd
[ 4.176263] isp 54600000.isp: initialized
[ 4.176312] driver not enabled, cannot register any devices
[ 4.177168] isp 54680000.isp: initialized
[ 4.177203] driver not enabled, cannot register any devices
[ 4.177736] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 4.181936] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 4.186141] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 4.187181] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 4.187736] last reset is due to power on reset
[ 4.187738] KERNEL: PMC reset status reg: 0x0
[ 4.187818] BL: PMC reset status reg: 0x0
[ 4.187820] BL: PMIC poweroff Event Recorder: 0x40
[ 4.189384] clk_cbus_recalc_rate: no gbus parent
[ 4.189388] clk_cbus_round_rate: no gbus parent
[ 4.189390] clk_cbus_round_rate: no gbus parent
[ 4.189397] clk_cbus_recalc_rate: no gbus parent
[ 4.189498] clk_cbus_recalc_rate: no gbus parent
[ 4.189501] clk_cbus_round_rate: no gbus parent
[ 4.189502] clk_cbus_round_rate: no gbus parent
[ 4.189505] clk_cbus_recalc_rate: no gbus parent
[ 4.190196] tegra_dvfs: GPU-cap: registered
[ 4.190250] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.190252] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.190254] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.191644] tegra_dvfs: vdd-gpu-vts: registered
[ 4.192574] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.193179] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.193947] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.237416] hctosys: …/drivers/rtc/hctosys.c: Ignoring backup rtc device (rtc0)
[ 4.238385] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.245112] tegra_rtc 7000e000.rtc: setting system clock to 1970-01-01 00:00:20 UTC (20)
[ 4.246231] vi 54080000.vi: vi_probe: ++
[ 4.248841] vi 54080000.vi: initialized
[ 4.250867] vi 54080000.vi: subdev nvcsi–2 bound
[ 4.250965] vi 54080000.vi: subdev nvcsi–1 bound
[ 4.250969] driver not enabled, cannot register any devices
[ 4.251531] mmcblk mmc0:0001: Card claimed for testing.
[ 4.252136] Disable partitions left on by BL
[ 4.252138] disb
[ 4.252173] bwmgr: missing cdev-type property
[ 4.252298] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.252304] DRAM derating cdev registered.
[ 4.253410] vdd-fan: disabling
[ 4.253413] vdd-usb-vbus: disabling
[ 4.253415] vdd-usb-vbus2: disabling
[ 4.253422] vddio-sdmmc-ap: disabling
[ 4.253508] vdd-3v3-sd: disabling
[ 4.253512] avdd-io-edp-1v05: disabling
[ 4.253513] vdd-usb-hub-en: disabling
[ 4.253589] ALSA device list:
[ 4.253592] #0: tegra-hda at 0x70038000 irq 80
[ 4.253593] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.259100] usb 1-2: New USB device found, idVendor=0424, idProduct=2734
[ 4.259104] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.259107] usb 1-2: Product: USB2734
[ 4.259109] usb 1-2: Manufacturer: Microchip Tech
[ 4.259876] hub 1-2:1.0: USB hub found
[ 4.259937] hub 1-2:1.0: 5 ports detected
[ 4.378429] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.390444] mmc1: host does not support reading read-only switch, assuming write-enable
[ 4.406929] usb 1-3: New USB device found, idVendor=0bda, idProduct=b82c
[ 4.406933] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.406936] usb 1-3: Product: 802.11ac NIC
[ 4.406938] usb 1-3: Manufacturer: Realtek
[ 4.406941] usb 1-3: SerialNumber: 123456
[ 4.534472] mmc1: hw tuning done …
[ 4.534536] mmc1: new ultra high speed SDR104 SDXC card at address 0007
[ 4.534905] mmcblk1: mmc1:0007 SD64G 58.2 GiB
[ 4.978431] usb 1-2.5: new high-speed USB device number 4 using tegra-xusb
[ 4.999786] usb 1-2.5: New USB device found, idVendor=0424, idProduct=2740
[ 4.999790] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.999792] usb 1-2.5: Product: Hub Controller
[ 4.999795] usb 1-2.5: Manufacturer: Microchip Tech
[ 6.081358] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 6.084445] Freeing unused kernel memory: 8576K
[ 6.095288] Extcon HDMI: HPD enabled
[ 6.095314] tegradc tegradc.0: hdmi: plugged
[ 6.128965] Root device found: mmcblk0p1
[ 6.135637] Found dev node: /dev/mmcblk0p1
[ 6.159934] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.170541] Rootfs mounted over mmcblk0p1
[ 6.197333] Switching from initrd to actual rootfs
[ 6.295464] systemd[1]: System time before build time, advancing clock.
[ 6.325390] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.343627] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.358211] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.384246] systemd[1]: Detected architecture arm64.
[ 6.423675] systemd[1]: Set hostname to .
[ 6.511526] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.530629] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.653728] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.664120] systemd[1]: Created slice System Slice.
[ 6.673599] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.682463] systemd[1]: Listening on Journal Audit Socket.
[ 6.692272] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.701117] systemd[1]: Listening on udev Control Socket.
[ 6.710966] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.722049] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.831329] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.909625] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.071193] systemd-journald[2057]: Received request to flush runtime journal from PID 1
[ 7.982991] EXT4-fs (mmcblk1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.991313] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.118465] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 8.118472] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 8.418717] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.439011] usb 2-1: New USB device found, idVendor=0424, idProduct=5734
[ 8.439016] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 8.439019] usb 2-1: Product: USB5734
[ 8.439022] usb 2-1: Manufacturer: Microchip Tech
[ 8.439884] hub 2-1:1.0: USB hub found
[ 8.439952] hub 2-1:1.0: 4 ports detected
[ 8.475025] usbcore: registered new interface driver btusb
[ 8.476587] Bluetooth: hci0: rtl: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[ 8.476594] Bluetooth: hci0: rtl: loading rtl_bt/rtl8822b_config.bin
[ 8.482447] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 8.482452] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 8.482454] rtk_btcoex: create workqueue
[ 8.482549] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 8.482628] usbcore: registered new interface driver rtk_btusb
[ 8.484441] Bluetooth: hci0: rtl: loading rtl_bt/rtl8822b_fw.bin
[ 8.485573] Bluetooth: hci0: rom_version status=0 version=2
[ 8.485606] Bluetooth: cfg_sz 14, total size 20270
[ 8.568145] 88x2bu: loading out-of-tree module taints kernel.
[ 8.653792] random: crng init done
[ 8.658752] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.809620] using random self ethernet address
[ 8.826407] using random host ethernet address
[ 9.002402] usb 2-1: usb_suspend_both: status 0
[ 9.002547] usb usb2: usb_suspend_both: status 0
[ 9.219401] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.219412] Bluetooth: BNEP socket layer initialized
[ 9.483907] Mass Storage Function, version: 2009/09/11
[ 9.483914] LUN: removable file: (no medium)
[ 9.492453] using random self ethernet address
[ 9.503813] using random host ethernet address
[ 9.543120] rndis0: HOST MAC 5e:ab:8f:2c:0e:78
[ 9.543384] rndis0: MAC 5e:ab:8f:2c:0e:79
[ 9.548988] usb0: HOST MAC 5e:ab:8f:2c:0e:7a
[ 9.549022] usb0: MAC 5e:ab:8f:2c:0e:7b
[ 9.549046] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 9.550134] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 9.550150] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.554466] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 9.554758] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 9.554773] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 9.562462] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 9.562483] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 9.562725] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 9.568549] l4tbr0: port 1(rndis0) entered blocking state
[ 9.568554] l4tbr0: port 1(rndis0) entered disabled state
[ 9.570243] device rndis0 entered promiscuous mode
[ 9.583593] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.590745] l4tbr0: port 2(usb0) entered blocking state
[ 9.590750] l4tbr0: port 2(usb0) entered disabled state
[ 9.591419] device usb0 entered promiscuous mode
[ 9.599471] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.768225] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.769352] eth0: 0xffffff800a44c000, 00:04:4b:e9:eb:de, IRQ 81
[ 9.879318] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.148443] zram: Added device: zram0
[ 10.154841] zram: Added device: zram1
[ 10.155313] zram: Added device: zram2
[ 10.157802] zram: Added device: zram3
[ 10.196617] zram0: detected capacity change from 0 to 518569984
[ 10.229336] Adding 506412k swap on /dev/zram0. Priority:5 extents:1 across:506412k SS
[ 10.245693] zram1: detected capacity change from 0 to 518569984
[ 10.272536] Adding 506412k swap on /dev/zram1. Priority:5 extents:1 across:506412k SS
[ 10.281696] zram2: detected capacity change from 0 to 518569984
[ 10.301210] Adding 506412k swap on /dev/zram2. Priority:5 extents:1 across:506412k SS
[ 10.305100] zram3: detected capacity change from 0 to 518569984
[ 10.319292] Adding 506412k swap on /dev/zram3. Priority:5 extents:1 across:506412k SS
[ 10.511159] usbcore: registered new interface driver rtl88x2bu
[ 10.553786] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.323365] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.375019] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.954922] r8168: eth0: link up
[ 12.954981] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.962793] tegradc tegradc.0: blank - powerdown
[ 18.016187] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 18.016189] Extcon AUX1(HDMI) disable
[ 18.036545] tegradc tegradc.0: unblank
[ 18.046618] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 18.046693] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 18.047699] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 18.047707] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 18.085281] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 18.085284] Extcon AUX1(HDMI) enable
[ 18.090352] tegradc tegradc.0: unblank
[ 22.582765] fuse init (API version 7.26)
[ 22.900691] tegradc tegradc.0: unblank
[ 38.198446] usb 1-2.3: new high-speed USB device number 5 using tegra-xusb
[ 38.219110] usb 1-2.3: New USB device found, idVendor=1a40, idProduct=0101
[ 38.219115] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 38.219119] usb 1-2.3: Product: USB 2.0 Hub
[ 38.221720] hub 1-2.3:1.0: USB hub found
[ 38.221809] hub 1-2.3:1.0: 4 ports detected
[ 38.510401] usb 1-2.3.1: new high-speed USB device number 6 using tegra-xusb
[ 38.546615] usb 1-2.3.1: New USB device found, idVendor=0bda, idProduct=5411
[ 38.546622] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 38.546626] usb 1-2.3.1: Product: 4-Port USB 2.0 Hub
[ 38.546630] usb 1-2.3.1: Manufacturer: Generic
[ 38.548018] hub 1-2.3.1:1.0: USB hub found
[ 38.549055] hub 1-2.3.1:1.0: 4 ports detected
[ 38.650466] usb 1-2.3.2: new full-speed USB device number 7 using tegra-xusb
[ 38.674023] usb 1-2.3.2: New USB device found, idVendor=046d, idProduct=c534
[ 38.674029] usb 1-2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 38.674032] usb 1-2.3.2: Product: USB Receiver
[ 38.674035] usb 1-2.3.2: Manufacturer: Logitech
[ 38.678611] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.0/0003:046D:C534.0001/input/input2
[ 38.739201] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-70090000.xusb-2.3.2/input0
[ 38.742975] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.1/0003:046D:C534.0002/input/input3
[ 38.802879] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-70090000.xusb-2.3.2/input1
[ 38.842486] usb 1-2.3.1.4: new high-speed USB device number 8 using tegra-xusb
[ 38.878800] usb 1-2.3.1.4: New USB device found, idVendor=0bda, idProduct=5411
[ 38.878806] usb 1-2.3.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 38.878809] usb 1-2.3.1.4: Product: 4-Port USB 2.0 Hub
[ 38.878812] usb 1-2.3.1.4: Manufacturer: Generic
[ 38.880132] hub 1-2.3.1.4:1.0: USB hub found
[ 38.881053] hub 1-2.3.1.4:1.0: 4 ports detected
[ 39.006410] usb 1-2.3.1.4: usb_suspend_both: status 0
[ 39.026746] usb 1-2.3.1: usb_suspend_both: status 0
[ 65.893061] usb 1-3: USB disconnect, device number 3
[ 66.028730] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 2
