I’m streaming chunks received rom openAI tts to the audio2face streaming player with a pyhton generator. It works, but the audio is distorted. The lipsync works. I dont get it… any idea?
def stream_audio_direct(response_stream, url, instance_name):
print("Entry in stream_audio_direct function.")
channel = grpc.insecure_channel(url)
stub = audio2face_pb2_grpc.Audio2FaceStub(channel)
samplerate = 24000
# Define the chunk size based on the sample rate
chunk_size = samplerate // 10 # This will determine how much data is processed at once
# Generator function to handle streaming
def generate_audio_requests():
# Send the start marker first
start_marker = audio2face_pb2.PushAudioRequestStart(
samplerate=samplerate, # Use the given samplerate
instance_name=instance_name,
block_until_playback_is_finished=True
yield audio2face_pb2.PushAudioStreamRequest(start_marker=start_marker)
# Buffer for audio data
buffer = bytearray()
for chunk in response_stream.iter_bytes():
buffer += chunk
# Process the buffer in chunks based on the calculated chunk size
while len(buffer) >= chunk_size:
# Adjust the buffer size to process only full chunks based on the audio format
if len(buffer) % 4 != 0:
# Ensure we only process complete 32-bit float samples
process_size = len(buffer) - (len(buffer) % 4)
else:
audio_data = np.frombuffer(buffer[:process_size], dtype=np.int16).astype(np.float32).tobytes()
#audio_data = buffer[:process_size].astype(np.float32).tobytes()
buffer = buffer[process_size:]
yield audio2face_pb2.PushAudioStreamRequest(audio_data=audio_data)
time.sleep(0.04) # Introduce a delay between sending chunks
# Handle any remaining buffer data
if len(buffer) > 0:
yield audio2face_pb2.PushAudioStreamRequest(audio_data=np.frombuffer(buffer, dtype=np.int16).astype(np.float32).tobytes())
# Create the streaming call
try:
responses = stub.PushAudioStream(generate_audio_requests())
for response in responses:
print("Received response from server:", response)
except Exception as e:
print(f"An error occurred: {e}")```
