Do Jetson Xavier support PyTorch C++ API?
Thanks,
Avi
YES.
But please remember to add -Wl,–no-as-needed
flag when building to load the library correctly.
Where do I need to add it in the make file?
And which C++ API version is supported for Jetson with JetPack 4.3?
You can check the Do Jetson Xavier support PyTorch C++ API? - #3 by AastaLLL for details.
There are some examples in the topic.
C++ pyTorch is supported for JetPack4.3
But please make sure you have installed the correct package which is built for JetPack4.3.
Can you please provide some information about using Libtorch inside a Pytorch docker on Xavier?
