Unable to install pytorch with cuda support on jetson AGX Xavier
I want to install pytorch with cuda support on jetson AGX Xavier (L4T 35.3.1).
From the https://pytorch.org/ , I came to know that pytorch only supports specific versions of cuda . In my case pytorch supports cuda 11.8 and 12.1 . But the one(cuda) which is default on L4T 35.3.1 is 12.2 . Anyhow I managed to uninstall it and installed the 11.8 version CUDA Toolkit 11.8 Downloads | NVIDIA Developer . Now my /usr/local/cuda/bin/nvcc --version shows 11.8.
Now I install pytorch with “pip3 install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu118” command.
After that I import torch and check for torch.cuda.is_available() . It still says false. How do I enable torch build with cuda on jetson? Any suggestions are welcomed.
Additional hint : on page http://download.pytorch.org/whl/cu118/torch/ page , there are many wheel file . For amd64 and x86 , the package name contains cu118(torch-2.0.0+cu118-cp38-cp38-linux_x86_64.whl ) . But for arch64 the package name doesnt contain cu118 ( torch-1.12.0-cp38-cp38-manylinux2014_aarch64.whl ) . I tried installing torch-1.12.0-cp38-cp38-manylinux2014_aarch64.whl , but torch.cuda.is_available() is still false.
@vikaash.kb revert to the original version of CUDA for JetPack 5 (which is CUDA 11.4) and then install one of the PyTorch wheels built for JetPack 5 from here:
You can also find instructions for building PyTorch from source in that thread if you desire.
