Hi everyone,
I wrote a simple code to test “do seq”
program seq
implicit none
integer::i,final
!$acc region
!$acc do seq
do i=1,10
final=i
end do
!$acc end region
write(*,*)final
end program
I thought the result would be “10” as that if I use “do host” in the above code.
However, the result is a random number.
Can anyone explain me the result? I think my understanding to “do seq” is wrong.
Thanks a lot.
Hi WENYANG LIU,
Scalars are privatized so the ‘final’ used in the kernel is different from the host’s copy of ‘final’, hence why you’re printing out seemingly random values (you’re really printing out uninitialized memory).
The work-around is to make final a single element array:
% a.out
10
xps730:/tmp/qa% cat seq.f90
program seq
implicit none
integer :: i, final(1)
!$acc region
!$acc do seq
do i=1,10
final(1)=i
end do
!$acc end region
print *, final(1)
end program
% pgf90 -ta=nvidia -Minfo seq.f90
seq:
5, Generating copyout(final(1))
Generating compute capability 1.0 binary
Generating compute capability 1.3 binary
Generating compute capability 2.0 binary
7, Parallelization would require privatization of array 'final(1)'
Accelerator kernel generated
7, !$acc do seq
CC 1.0 : 2 registers; 0 shared, 8 constant, 0 local memory bytes; 33% occupancy
CC 1.3 : 2 registers; 0 shared, 8 constant, 0 local memory bytes; 25% occupancy
CC 2.0 : 4 registers; 0 shared, 40 constant, 0 local memory bytes; 16% occupancy
% a.out
10
While this ‘works’, you generally only want to use sequential code within a parallel region. Running purely sequential code on a GPU will be quite slow.
