Do transfer learnning using TAOT
• Hardware (T4/V100/Xavier/Nano/etc) t4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) Detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) tao version : 5.5
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
hi i want to do transfer learning in detectnet_v2 but i’m new in TAO
can you help me to undrastand some of thease?
how can i learn more about spec file? i didn’t find any toturial about it (the only thing i find is notebooks without any explanation about what exactly spec file is or showing me all parameters of it(with explanation))
can i do transfer learning by changing spec file or other things? what should i do for it? (fore example changing output layer and keeping feature extraction layers and then fine tuning in new data)
For detectnet_v2, the notebook is in https://github.com/NVIDIA/tao_tutorials/tree/main/notebooks/tao_launcher_starter_kit/detectnet_v2.
The doc is in DetectNet_v2 — Tao Toolkit.
The code is in tao_tensorflow1_backend/nvidia_tao_tf1/cv/detectnet_v2 at main · NVIDIA/tao_tensorflow1_backend · GitHub.
Yes, you can change spec file or other things.
You can also docker run into the docker(nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5) (from TAO Toolkit | NVIDIA NGC). And modify the code and then docker commit to save your changes for your further use.
