DOCA sample compile error
I have tried to compile sample code on BF2, but face error below. And I have tried the method in document 1.1. Meson Complains About Missing Dependencies . It still didn’t work, How to fix the problem thx.
ubuntu@localhost**:/opt/mellanox/doca/samples/doca_flow/flow_monitor_meter$ sudo meson build
The Meson build system
Version: 0.61.2
Source dir: /opt/mellanox/doca/samples/doca_flow/flow_monitor_meter
Build dir: /opt/mellanox/doca/samples/doca_flow/flow_monitor_meter/build
Build type: native build
Program cat found: YES (/usr/bin/cat)
Project name: DOCA_SAMPLE
Project version: 1.5.0055
C compiler for the host machine: cc (gcc 9.4.0 “cc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0”)
C linker for the host machine: cc ld.bfd 2.34
C++ compiler for the host machine: c++ (gcc 9.4.0 “c++ (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0”)
C++ linker for the host machine: c++ ld.bfd 2.34
Host machine cpu family: aarch64
Host machine cpu: aarch64
Found pkg-config: /usr/bin/pkg-config (0.29.1)
Found CMake: /usr/bin/cmake (3.16.3)
Run-time dependency doca-common found: NO (tried pkgconfig and cmake)
meson.build:29:0: ERROR: Dependency “doca-common” not found, tried pkgconfig and cmake
I also got the same error. The information provided in the trouble shooting document did not work. Please provide any suggestion.
I have tried to unset PKG_CONFIG_PATH and tried to follow trouble shooting document again and it worked
try with command “sudo -E meson build” which passes user environmental variables to sudo
Have you tried setting these environment variables?
export PKG_CONFIG_PATH=${PKG_CONFIG_PATH}:/opt/mellanox/doca/lib/aarch64-linux-gnu/pkgconfig:/opt/mellanox/flexio/lib/pkgconfig
export PKG_CONFIG_PATH=${PKG_CONFIG_PATH}:/opt/mellanox/dpdk/lib/aarch64-linux-gnu/pkgconfig
export PATH=${PATH}:/opt/mellanox/doca/tools
-J
I had a runtime dependency to doca, without the -common, but your advise was a solution for me. Thanks.
After this, I am wondering that if we can compile source on the Bluefield, why does the documentation recommend us to install and download a dev-container on the Bluefield. For now, it seems like an unnecessary extra layer that can clearly complicate things when it comes to remote code development…
I want to run the ARM storm sample app that is using doca-flow. But after trying to compile it, now I have a similar issue as above w.r.t. doca-flow.
Run-time dependency doca-flow found: NO (tried pkgconfig and cmake)
meson.build:37:0: ERROR: Dependency "doca-flow" not found, tried pkgconfig and cmake
The above exports do not help, but I indeed see the libdoca_flow modules under the path we add, i.e., /opt/mellanox/doca/lib/aarch64-linux-gnu/
Any suggestions?
“vim /etc/profile”, then add below command to the tail!
export PKG_CONFIG_PATH=/opt/mellanox/doca/lib/aarch64-linux-gnu//pkgconfig/:/opt/mellanox/dpdk/lib/aarch64-linux-gnu/pkgconfig/:/opt/mellanox/flexio/lib/pkgconfig/:/opt/mellanox/grpc/lib/pkgconfig/:/opt/mellanox/grpc/share/pkgconfig/:/opt/mellanox/spdk/lib/pkgconfig/
then exec command “source /etc/profile”;
anyway , you‘d better be root role
