You shouldn’t need to build the jetson-inference container yourself (unless you want to). For L4T r32.7.2, use the dusty-nv/jetson-inference:r32.7.1
It would seem this error is related to this:
opened 11:02AM - 20 Jan 23 UTC
Unsure where this goes, feel free to close if inappropriate.
Here's me downlo… ading `dustynv/ros:humble-ros-base-l4t-r35.1.0` and trying to run `apt update`.
$docker run -it --network=host dustynv/ros:humble-ros-base-l4t-r35.1.0 apt update
sourcing /opt/ros/humble/install/setup.bash
ROS_ROOT /opt/ros/humble
ROS_DISTRO humble
Get:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease [265 kB]
Get:2 https://repo.download.nvidia.com/jetson/common r35.1 InRelease [2,555 B]
Get:3 http://packages.ros.org/ros2/ubuntu focal InRelease [4,685 B]
Get:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease [108 kB]
Get:6 https://repo.download.nvidia.com/jetson/common r35.1/main arm64 Packages [19.1 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [114 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal/multiverse arm64 Packages [139 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal/main arm64 Packages [1,234 kB]
Get:10 https://apt.kitware.com/ubuntu focal InRelease [15.5 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports focal/restricted arm64 Packages [1,317 B]
Get:12 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 Packages [11.1 MB]
Get:13 http://packages.ros.org/ros2/ubuntu focal/main arm64 Packages [1,143 kB]
Err:10 https://apt.kitware.com/ubuntu focal InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 42D5A192B819C5DA
Get:14 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages [1,193 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports focal-updates/multiverse arm64 Packages [9,068 B]
Get:16 http://ports.ubuntu.com/ubuntu-ports focal-updates/restricted arm64 Packages [5,265 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 Packages [2,102 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports focal-backports/universe arm64 Packages [27.8 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports focal-backports/main arm64 Packages [54.8 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports focal-security/multiverse arm64 Packages [3,252 B]
Get:21 http://ports.ubuntu.com/ubuntu-ports focal-security/main arm64 Packages [1,714 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 Packages [892 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports focal-security/restricted arm64 Packages [5,003 B]
Reading package lists... Done
W: GPG error: https://apt.kitware.com/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 42D5A192B819C5DA
E: The repository 'https://apt.kitware.com/ubuntu focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
It fails due to some GPG error. Any image I base on this image will have errors running `apt update`, which means that `apt update && ...` always fails. A quick google suggests that this is a manual fix of adding a public key (listed in the error message), so is this something that should be added to your image or is it a matter of waiting for someone else to update their public keys?
Try adding this to your docker file before apt update
is run:
RUN wget -O - https://apt.kitware.com/keys/kitware-archive-latest.asc 2>/dev/null | gpg --dearmor - | tee /usr/share/keyrings/kitware-archive-keyring.gpg >/dev/null \
&& echo 'deb [signed-by=/usr/share/keyrings/kitware-archive-keyring.gpg] https://apt.kitware.com/ubuntu/ focal main' | tee /etc/apt/sources.list.d/kitware.list >/dev/null
