As a sanity check, does this happen when you use the device names as MIG- like described by https://docs.nvidia.com/datacenter/tesla/mig-user-guide/#running-containers ?
ScottE
ScottE
| Training in TAO 3.0 in DGX inside docker-compose for multi-gpus MIG | 4 | 1561 | January 28, 2022 | |
| Is it possible to have one MIG device recognized as one GPU in a docker container? | 0 | 176 | May 16, 2025 | |
| What is the meaning of the statement 'only enumeration of a single MIG instance is supported'? | 0 | 126 | June 9, 2025 | |
| Docker unable to start when using MIG GPU devices | 3 | 855 | February 14, 2025 | |
| Can not run mig in docker container on Jetson Thor | 9 | 317 | September 14, 2026 | |
| Getting the Most Out of the NVIDIA A100 GPU with Multi-Instance GPU | 11 | 2075 | January 19, 2023 | |
| Is supported multiple MIG instances with R550 & CUDA12.1? | 2 | 249 | June 5, 2025 | |
| Trouble starting docker container with cuda after enabling MIG | 14 | 330 | September 21, 2026 | |
| Pytorch issue with MIG instances created on A100 | 1 | 1223 | June 30, 2022 | |
| MIG : Failed to attach MIG with container on specific 8 A100 GPU server on Ubuntu | 1 | 868 | October 6, 2022 |
