I am running ubuntu 22
`Linux bizmate-i7 6.8.0-87-generic #88~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Oct 14 14:03:14 UTC 2 x86_64 x86_64 x86_64 GNU/Linux`
Nvidia driver correctly installed and detecting the RTX 2027
$ nvidia-smi
Fri Nov 14 13:22:08 2025
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2070 Off | 00000000:09:00.0 On | N/A |
| 0% 50C P8 21W / 175W | 296MiB / 8192MiB | 7% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 5660 G /usr/lib/xorg/Xorg 139MiB |
| 0 N/A N/A 5834 G /usr/bin/gnome-shell 14MiB |
| 0 N/A N/A 5987 G /usr/bin/nextcloud 1MiB |
| 0 N/A N/A 11599 G cairo-dock 6MiB |
| 0 N/A N/A 11712 G …rack-uuid=3190708988185955192 119MiB |
However today i cannot run a docker container with GPU capabilities. I tried to reinstall the latest toolkit, as per Installing the NVIDIA Container Toolkit — NVIDIA Container Toolkit and on the same page i run configuration and then restarted docker.
First of all i cannot run the documented command as is ie runtime nvidia fails to run
$ docker run --rm --runtime=nvidia --gpus all nvcr.io/nvidia/cuda:13.0.2-cudnn-runtime-ubuntu24.04 nvidia-smi
docker: Error response from daemon: unknown or invalid runtime name: nvidia
But also by removing the runtime it still fails suggesting there are no devices with gpu capabilities
$ docker run --rm --gpus all nvcr.io/nvidia/cuda:13.0.2-cudnn-runtime-ubuntu24.04 nvidia-smi
docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]]
Could you suggest what I am missing here?
