Documentation for TensorRT
Hi there friends! I am trying to use TensorRT to deploy some networks but I am having a bit of a hard time to deploy it in other than the TX1, this link has helped me a little (GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.)
But I can’t find the documentation for TensorRT no matter where I look, I installed it from the deb package at the Nvidia page, the name is: nv-gie-repo-ubuntu1404-ga-cuda8.0-gie1.0-20170116_6-1_amd64
A friend told me that the docs and examples are in /usr/src/gie_samples and /usr/share/doc/gie
But I still can’t find it. Anyone knows where should I look?
All help is appreciated!
@bpinaya
I als0 studying TensoRT,[url]https://developer.nvidia.com/nvidia-tensorrt-download[/url]
Quick Start Instructions
Verify that you have the CUDA toolkit installed, release 7.5 or 8.0 .
Download the TensorRT debian package (below)
Install GIE from the debian package:
sudo dpkg -i nv-gie-repo-ubuntu1404-ga-cuda8.0-gie1.0-20170116_6-1_amd64.deb
sudo apt-get update
sudo apt-get install libgie1
sudo apt-get install libgie-dev
Verify your installation:
dpkg -l | grep libgie
and you should see:
ii libgie-dev 1.0.0-1+cuda8.0 arm64 GIE development libraries and headers
ii libgie1 1.0.0-1+cuda8.0 arm64 GIE runtime libraries
you need libgie1 libgie-dev ,and you should makesure your os version is correct.TensorRT 1.0 only support Ubuntu14.04.
Hey @gu_xiangtao, I follow the steps, but after:
sudo apt-get update
I get:
E: Unable to locate package libgie1
I have cuda installed already, can’t seems to find a solution to this one.
To give an update I got it to locate libgie1, but now it throws this error:
The following packages have unmet dependencies:
libgie1 : Depends: cuda-cublas-8-0 but it is not installable
E: Unable to correct problems, you have held broken packages.
Tried looking around for that dependency but couldn’t find it.
Nvcc version is:
Cuda compilation tools, release 8.0, V8.0.61
Hi bpinaya,
I just tried your installation steps. It’s fine on my machine:
$ sudo apt-get install libgie1
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following extra packages will be installed:
libcudnn5
The following NEW packages will be installed:
libcudnn5 libgie1
0 upgraded, 2 newly installed, 0 to remove and 219 not upgraded.
Need to get 0 B/46.4 MB of archives.
After this operation, 132 MB of additional disk space will be used.
Do you want to continue? [Y/n]
I think you can try again in a fresh environment.
sudo apt-get --remove purge “cuda*”
sudo apt-get --remove purge “nv…(related pack)”
sudo apt-get autoremove
dpkg -l | grep ^rc | cut -d’ ’ -f3 | sudo xargs dpkg -P
Then install cuda(sudo apt-get install cuda-toolkit-8-0), gie again.
