Micro SDXC, Read: 275MB/s, write: 100MB/s
I don’t know if I can support it.
Hi, it is up to 104MBps, please check the OEM DG and module datasheet in DLC: https://developer.nvidia.com/embedded/downloads
Thank you!
Hello, @Trumany
When using the Jetson nano emmc module, how much SD card capacity is available when the carrier board supports an external SD card slot?
Thank you.
It’s up to 2TB.
