I am unable to open two identical USB 3.0 cameras simultaneously on my Orin NX. Each camera works fine individually, but when I try to open both at the same time, the second camera always fails to open due to “not enough bandwidth,” even when using a very low resolution (640x480). Therefore, this should not be a bandwidth limitation. Does Orin NX not support multiple USB 3.0 cameras being opened simultaneously?
Here is some information about my cameras:
ls /dev/video*
output
/dev/video0
/dev/video1
/dev/video2
/dev/video3
lsusb -t
output
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
|__ Port 1: Dev 6, If 1, Class=Video, Driver=uvcvideo, 5000M
|__ Port 1: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
|__ Port 1: Dev 6, If 0, Class=Video, Driver=uvcvideo, 5000M
|__ Port 3: Dev 7, If 0, Class=Video, Driver=uvcvideo, 5000M
|__ Port 3: Dev 7, If 1, Class=Video, Driver=uvcvideo, 5000M
|__ Port 3: Dev 7, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 3: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
First camera test command and output
ffplay -f v4l2 -input_format mjpeg -framerate 30 -video_size 1640x480 /dev/video0
libEGL warning: DRI3: failed to query the version
ffplay version 4.4.2-1ubuntu0.1 Copyright (c) 2003-2021 the FFmpeg developers
built with gcc 11 (Ubuntu 11.4.0-1ubuntu1~22.04)
configuration: --prefix=/usr --enable-nvv4l2dec --enable-libv4l2 --enable-shared --extra-libs='-L/usr/lib/aarch64-linux-gnu/tegra -lv4l2 -lnvbufsurface -lnvbufsurftransform' --extra-cflags=-I/usr/src/jetson_multimedia_api/include/ --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
[video4linux2,v4l2 @ 0xffff20000c10] The V4L2 driver changed the video from 1640x480 to 640x480
[video4linux2,v4l2 @ 0xffff20000c10] The driver changed the time per frame from 1/30 to 1/60
Input #0, video4linux2,v4l2, from '/dev/video0':
B sq= 0B f=0/0 Duration: N/A, start: 8577.312162, bitrate: N/A
Stream #0:0: Video: mjpeg (Baseline), yuvj422p(pc, bt470bg/unknown/unknown), 640x480, 60 fps, 60 tbr, 1000k tbn, 1000k tbc
[swscaler @ 0xffff1c0b1550] deprecated pixel format used, make sure you did set range correctly
[swscaler @ 0xffff1c0b1550] No accelerated colorspace conversion found from yuv422p to rgba.
Second camera test command and error
ffplay -f v4l2 -input_format mjpeg -framerate 30 -video_size 1640x480 /dev/video2
[video4linux2,v4l2 @ 0xffff44000c10] The V4L2 driver changed the video from 1640x480 to 640x480
ioctl(VIDIOC_STREAMON): No space left on device /dev/video2: No space left on device
dmesg
log when running the second camera
[ 8583.662899] usb 2-1.3: Not enough bandwidth for altsetting 11
[ 8844.000869] usb 2-1.3: Not enough bandwidth for new device state.
[ 8844.000891] usb 2-1.3: Not enough bandwidth for altsetting 11
