About the specifications of Jetson Xavier NX (USBcamera)
I want to connect multiple USB cameras to Jetson xavier NX and run the AI algorithm.
With two USB cameras, it works fine, but with three USB cameras, it doesn’t work because the bandwidth is insufficient.
Error message: No space left on device
Camera used: ELP-USBFHD01M-BL28
High frame rate MJPEG 30 fps @ 1920 (H) x 1080 (V)
USB2.0
Does anyone know the solution?
The behavior is same as on Jetson Nano. Please check the explanation in
We suggest use USB3 cameras to get more bandwidth.
