How jetson nano , connect 4 usb camera?
hi, i use jetson nano ,i can conect 2 usb camera is ok ,but when i start connect 3 usb camera,it error ?
My Purpose is use 4 usb camera in 1 jetson nano ,Can do it?
opencv , python 3.6
Thank you very much
You may hit bandwidth constraint if you use USB2 cameras. Please refer to
connected more than two usb cameras problem on deepstream-app (Jetson Nano Dev Kit) - #12 by DaneLLL
Suggest try USB3 cameras and have external power supply.
Thanks for the response.
i use ELP cameara ,and i want to connect 4 camera in onetime, but when i connect 3 or 4 camera it error ā€œjetson nano vidioc_streamon: no space left on deviceā€ ,how to Solve the problem or explain about problem.
Thank you very much
The case does not work on default devkit. Suggest you check other carrier board from our partners:
https://developer.nvidia.com/embedded/community/ecosystem?category=hardware_design_services_hardware_design_services
Thank you very much
