During building opencv-4.1.0 I realize that nvcc (10.1) just compiles *.cu files in sequence one by one. That delays the building progress significantly.
I wonder if nvcc supports compiling in parallel? If it does not, what is reason behind it and if it does, what is proper way to enable?
If you’d like to see a change, you’re welcome to request that using the bug reporting system (perhaps add RFE keyword to description): the instructions are linked to a sticky post at the top of this forum.
Thank you for reply,
I am confused that according to you, nvcc does not support compiling in parallel, how external utils could make nvcc become supported?
I am quite surprised that CUDA has been popular for years but still it does not support multi-core world.
Perhaps you should study how make -j works. That has nothing to do with CUDA, but it can certainly work with nvcc.
I guess the same could be said for g++
–threads option was added to nvcc in CUDA 11.3
