Is there a compiler swithc to parallize the source file compilation for the NVCC compiler across all CPU cores - in the same way as it is possible for the Visual Studio compiler via the ‘/MP’ switch (see Sam's Blog » Blog Archive » Multi-processor building in Visual Studio 2005) ?
Related topics
| Does nvcc support compiling in parallel? | 5 | 3640 | August 3, 2022 | |
| Can nvcc generate code for multiple architectures in parallel | 4 | 5705 | February 4, 2025 | |
| Nvc++ doesn't parallelise across cpu cores if -stdpar is not specified | 1 | 510 | August 6, 2020 | |
| Super NVCC? 25% performance improvement | 5 | 2287 | March 21, 2009 | |
| Difference in Performance | 13 | 9873 | August 20, 2008 | |
| Building CUDA kernels in parallel in VS2013? | 2 | 2198 | July 17, 2015 | |
| Parallel compilation with NVRTC | 4 | 1057 | February 28, 2024 | |
| Multcore host | 1 | 1815 | September 23, 2011 | |
| Which threading library does -stdpar=multicore use? | 3 | 880 | July 2, 2022 | |
| Multithreaded build VS2008 support multithreaded build with /MP [n]. nvcc adds /E though.. | 3 | 8794 | October 9, 2010 |
