I want to know NVIDIA Video Codec SDK supports ARM.
I’m trying to hardware encode by NVENC + Video Codec SDK on ARM machine(AWS EC2 G5g insntance/NVIDIA T4G).
Though system requirements doesn’t say SDK supports ARM, It seems that ffmpeg with NVIDIA GPU haredware acceleration work properly on AWS EC2 G5g insntance/NVIDIA T4G from the following logs.
$ ffmpeg -y -hwaccel cuda -hwaccel_output_format cuda -i yuv420p.y4m -c:v h264_nvenc output.mp4
ffmpeg version N-107322-g03d81a044a Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
configuration: --enable-nonfree --enable-cuda-nvcc --enable-libnpp --extra-cflags=-I/usr/local/cuda-11.7/include --extra-ldflags=-L/usr/local/cuda-11.7/lib64
libavutil 57. 27.100 / 57. 27.100
libavcodec 59. 36.100 / 59. 36.100
libavformat 59. 26.100 / 59. 26.100
libavdevice 59. 6.100 / 59. 6.100
libavfilter 8. 41.100 / 8. 41.100
libswscale 6. 6.100 / 6. 6.100
libswresample 4. 6.100 / 4. 6.100
Input #0, yuv4mpegpipe, from 'yuv420p.y4m':
Duration: 00:00:13.51, start: 0.000000, bitrate: 745751 kb/s
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, top first), 1920x1080, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 29.97 tbn
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc))
Press [q] to stop, [?] for help
Output #0, mp4, to 'output.mp4':
Metadata:
encoder : Lavf59.26.100
Stream #0:0: Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, top coded first (swapped)), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 2000 kb/s, 29.97 fps, 30k tbn
Metadata:
encoder : Lavc59.36.100 h264_nvenc
Side data:
cpb: bitrate max/min/avg: 0/0/2000000 buffer size: 4000000 vbv_delay: N/A
frame= 405 fps=319 q=32.0 Lsize= 3462kB time=00:00:13.38 bitrate=2119.4kbits/s speed=10.5x
video:3458kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.118147%
