Does the 256GB SD card work with the Jetson AGX Orin Development Kit?
I’m working on the Jetson AGX Orin 32GB Development Kit.
It only has 64GB of internal emmc, which is insufficient for me as I install many applications like docker and other things. Now that I have the plan to use an SD card and boot from an SD card, could you kindly let me know what size of SD card the Jetson AGX Orin dev kit will support?
Regards,
Parashuram
Orin devkit should support up to 1 TB, thus 256GB is not problem.
Thank you for your response.
