I have checked the following topic:
https://devtalk.nvidia.com/default/topic/1026493/jetson-tx1/lossless-h-264-encoding/post/5220785/#5220785
I tested this command:
gst-launch-1.0 nvcamerasrc num-buffers=150 ! omxh264enc control-rate=0 qp-range=0,1:0,1:0,1 quant-i-frames=0 quant-p-frames=0 ! 'video/x-h264,stream-format=byte-stream' ! filesink location=a.h264
I also can see few bits in wrong values.
But I need really accomplish lossless compression.
Could you help me on this issue?
