DPDK procedure for 1M/sec flow insertion rate
The DPDK mlx5 guide lists as a feature “Flow insertion rate of more then million flows per second, when using Direct Rules”. I would appreciate any information on a test setup that supports this rate.
I have both ConnectX-5 and ConnectX-6 NICs. Using the dpdk-test-flow-perf program from DPDK 24.11.1 running on Ubuntu 24.04 with doca-roce-2.9.1-0.1.9, I see a maximum of 350K inserts/sec.
Given there is a potential 3x speedup, it would be very helpful to hear what hardware, driver, DPDK command, and DPDK code used to insert 1M/sec. That might guide me (and others) to determine if my issue is hardware (maybe only certain cards can reach that rate?) or software (driver or DPDK).
Hi brian
You should Use HW steering to get max performance:
HW steering:
  • WQE based high scaling and safer flow insertion/destruction.
  • Set dv_flow_en to 2 in order to enable HW steering.
  • Async queue-based rte_flow_async APIs supported only.
  • NIC ConnectX-5 and before are not supported.
  • Reconfiguring flow API engine is not supported. Any subsequent call to rte_flow_configure() with different configuration than initially provided will be rejected with -ENOTSUP error code.
  • Partial match with item template is not supported.
  • IPv6 5-tuple matching is not supported.
  • With E-Switch enabled, ports which share the E-Switch domain should be started and stopped in a specific order:
    • When starting ports, the transfer proxy port should be started first and port representors should follow.
    • When stopping ports, all of the port representors should be stopped before stopping the transfer proxy port.If ports are started/stopped in an incorrect order, rte_eth_dev_start()/rte_eth_dev_stop() will return an appropriate error code:
    • -EAGAIN for rte_eth_dev_start().
    • -EBUSY for rte_eth_dev_stop().
  • Matching on ICMP6 following IPv6 routing extension header, should match ipv6_routing_ext_next_hdr instead of ICMP6. IPv6 routing extension matching is not supported in flow template relaxed matching mode (see struct rte_flow_pattern_template_attr::relaxed_matching).
  • The supported actions order is as below:
MARK (a) *_DECAP (b) OF_POP_VLAN COUNT | AGE METER_MARK | CONNTRACK OF_PUSH_VLAN MODIFY_FIELD *_ENCAP (c) JUMP | DROP | RSS (a) | QUEUE (a) | REPRESENTED_PORT (d)
  1. Only supported on ingress.
  2. Any decapsulation action, including the combination of RAW_ENCAP and RAW_DECAP actions which results in L3 decapsulation. Not supported on egress.
  3. Any encapsulation action, including the combination of RAW_ENCAP and RAW_DECAP actions which results in L3 encap.
  4. Only in transfer (switchdev) mode.
https://doc.dpdk.org/guides/nics/mlx5.html#features
More information you can contact networking-support@nvidia.com
