Good day!
There is a server with Mellanox ConnectX-3 FDR InfiniBand + 40GigE, model: CX354A. Firmware version 2.42.5000. Running ubuntu LTS 16.04.3. Mlnx_ofed_linux driver installed-4.4-2.0.7.0-ubuntu16.04-x86_64 with --dpdk --upstream-libs keys. Dpdk 16.04 is installed.
Dpdk applications work, but if you put one of the ports on the mellanox Board into infiniband mode, the applications stop working. Is it possible to use one of the ports of this Board in infiniband mode, and the second to use for dpdk applications?
Thank you in advance.
Sincerely, Artem!
