Draw Bounding Boxes for One Specific Class
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0 (5.0-20.07 docker)
• NVIDIA GPU Driver Version (valid for GPU only) 465
• Issue Type( questions, new requirements, bugs) Question
I’m using deepstream-test3 and only want to display bounding boxes for Vehicle class.
I have tried using function nvds_remove_obj_meta_from_frame to remove obj_meta for objects belong to other classes but not success.
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        //int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
                obj_meta->rect_params.border_color.red = 0.0;
                obj_meta->rect_params.border_color.green = 1.0;
                obj_meta->rect_params.border_color.blue = 0.0;
            else {
                obj_meta->rect_params.border_color.green = 0.0;
                obj_meta->rect_params.border_color.blue = 1.0;
                nvds_remove_obj_meta_from_frame(frame_meta, obj_meta);
          g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_meta->frame_num, num_rects, vehicle_count, person_count);
Bounding boxes for people are still showing in output frames but in default red color. May I know why this happened and what is the correct way to remove obj_meta?
deepstream_test3_app.c (17.9 KB)
Here is my modified codes.
I haven’t changed engine configuration and other files.
Can you have a check if there is only Vehical class obj in the meta after your remove function?
Hi kesong,
I have checked and found non-vehical class metadata are still there after I call nvds_remove_obj_meta_from_frame function.
May I know the correct way to remove obj_meta from frame_meta?
Thank you!
Suppose it should work.
Here is api doc.
https://docs.nvidia.com/metropolis/deepstream/sdk-api/index.html
